Question about Motorola XV2600 (6 Channels) 2-Way Radio
How do i change channels on the xv2600 - Motorola XV2600 (6 Channels) 2-Way Radio
  • Motorola Master
  • 1,654 Answers
Here is a link to the manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/XTN_Series_User_Manual_E.pdf
To put the radio in programming mode you hold in the PTT and the MON buttons while turning it on. Continue to hold them in until the initialization noise finishes. Then use the MENU button and the + and - buttons to program. The complete directions are in the user manual linked above.
Best regards.
Posted on Nov 14, 2009
UNLCOCK MOTOROLA XTN SERIES
Here's a link to the manual where you will find programming info https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwi41fis6eLJAhUF5CYKHTgFAFQQFggdMAA&url=https%3A%2F%2Fwww.buytwowayradios.com%2FProducts%2FMotorola%2Fmanuals%2FXTN-series-manual.pdf&usg=AFQjCNFIOd86CBLE45ZNgdfTwEtH6ZhRsA&cad=rja
Oct 08, 2013 | Motorola XV2600 (6 Channels) 2-Way Radio
Xtn series won't transmit through remote microphone
Here are a handful of problems you might be having:
1) Be certain the radio is turned OFF when plugging in an audio device.
2) Be certain the remote mic is plugged all the way in, until you feel a slight click.
3) Your accessory jack could be wobbled or worn from plugging and unplugging chargers/audio devices. If so, the radio would need repair.
4) Your remote mic is not working. Try it on another unit to confirm.
5) Or the remote mic is not the one designed to go with the XTN radio.
Best regards.
Jun 18, 2012 | Motorola XV2600 XTN Series Portable...
Motorola xv2600 has only 2 channels instead of 6. can not reset to default, i.e., 6 channels, will not reset if mager lock on. how to turn off lock ?
Place the radio in programming mode by holding in the PTT and MON while turning the radio on. Press the menu button until you get to the lock indicator. It will have a Y for yes. using your + or - button change this to an N for no. then proceed with pressing the menu button. Continue using the menu button until you get to the CH and change your 2 to a 6. Here is a link to the user guide for more programming details: http://www.123radios.com/manuals/xtnmanual.pdf
best regards.
Nov 05, 2011 | Motorola XV2600 (6 Channels) 2-Way Radio
Have 3 xv2600 radios one needs to be programed to the other 2
Here is a link to the user guide: http://www.123radios.com/manuals/xtnmanual.pdf Instructions for programming begin on page 18. There are several steps to programming, use the menu button to walk you through the steps. All the radios much match identically in programming to work together.
Best regards.
Jan 11, 2011 | Motorola XV2600 (6 Channels) 2-Way Radio
Aveis LT15AP3
AVEIS LT15AP3; WHEN CHANGING THE CHANNEL BY LAST CHANNEL OR BY PUTTING IN ACTUAL CHANNEL , IT DOES NOT CHANGE TO CHANNEL I PUNCHED IN BUT TO CABLE CHANNEL 3. IF I TURN TV OFF AND HAVE THE CHANNEL I WANT ON, IT COMES ON THAT CHANNEL. THEN IF I CHANGE CHANNEL IT GOES BACK TO CHANNEL 3. HELP????
Apr 14, 2010 | Televison & Video
I need to fix the frequency to match my other motorola XTN series radio model #XV2600 to my new motorola RDM2070d radio
Here is a link to the CP100 user manual, it is the sister radio2.gif to the XTN, and programs the same way. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Refer to the bottom of page 20 to get started programming2.gif.
Basically you hold in the PTT and the MON button while turning the radio on. Continue to hold them in until it stops making noise. This puts you in programming mode, and you can use the menu button and the + and - to walk you through reprogramming the radio.
We do not know specifically how your RDM2070d radio is programmed. You would need to know this to program your XTN to match. However, a good educated guess would be to start with Blue dot and Green dot frequencies off of the frequency chart in the user manual listed above. An educated guess on the code setting would be "zero" or "off".
Your radio dealer who supplied the RDM2070d radios to your corporation should be able to tell you the exact frequency and code; or read-out the radio.
Nov 03, 2009 | Motorola XTN Series Pro Two-Way Radio...
No user manual for the RDV2080d
Here is a link to the programming software http://www.radioserviceincorporated.com/files/1935423/uploaded/RDX_Series_CPS_R01-00.zip
And here is a link to the user guide http://www.astracomm.com/media/pdf/RDX_Display.pdf
The RDV2080 VHF with display would be compatible with the XTN series radios which have a model name starting with XV, as in VHF. Typically the RDV2080 ships on the default frequencies found in the XV2600. So if you have not changed your XTN frequencies/PL code they may match out of the box.
On a sidenote: The Motorola CP110 VHF is also compatible. It is an industrial version of the RDX radio. It has a few more channel capability and a replaceable antenna. It looks just like the RDX models, and it is the replacement radio for the CP100 and/or XTN.
All of the above mentioned models are repairable.
Jul 20, 2009 | Motorola RDV2080d Two Way Radio
Remote only advances by one channel.
The button on the remote next to 0 and below 9 has to be depressed to _ _ before you select any 2 digit channels. I had the same problem and accidently figured it out. Hope it helps. TC
Jul 13, 2008 | Memorex MT2206 TV
Motorola XV2600 (6 Channels) 2-Way Radio Logo
136 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
