Question about Maytag Washing Machines
Maytag Atlantis washer MAVT754EWW tub does not spin. Motor and Belt spin.
SOURCE: my maytag atlantis won't spin just makes noise
The transmission has a very poorly made gear with 2 tabs on it in center- botton of the transmission inside these tabs break off then it won't spin, i got 2 0f them here now and no part to fix them with , Maytag should made supply the part to fix it with, they want to sell you a whole transmission at better that 200.00 , Jimmy T.
Posted on Jan 17, 2008
IrishDruid
  • 2712 Answers
SOURCE: Maytag Atlantis MAV200AWW Top Load
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Posted on Jul 01, 2008
  • 4 Answers
SOURCE: maytag atlantis will agitate won't spin
I had the same problem with my Atlantis a couple of months ago. It turned out to be the bearing for the tub drive pulley. When you look under the washer there are three pulleys. The one for the motor is ont he left, the drain pulley on the right and the big one in the middle for the tub. What I found is that when the bearing went bad, the tub would fill and turn for washing, but it would not turn at all for spinning. I could turn the pulley by hand but the tub refused to budge. I removed the main pulley and could see that the bearing had exploded. You can't buy just the bearing but the whole pulley kit is like $35 so I got off easy. I put the machine back together (which is tricky) but it works fine now. The pulley kit comes with complete instructions but it's really straightforward. The tricky part is that you have to pull down on the end of the drive shaft in order to get the retainer ring onto the pulley. That can be difficult if you don't have a lot of room to work or have a partner to assist. You can replace the whole thing or just the bearing and save the pulley for a rainy day if you want. I opted for the whole replacement. But I saved the old. cause ya neva know!
Posted on Jan 16, 2009
  • 25 Answers
SOURCE: Describe your Maytag Atlantis MAV6000 Top LoaI
drive unit faulty/or faulty lid microswitch
Posted on Jul 13, 2009
SOURCE: I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Posted on Feb 06, 2010
I have a Maytag Atlantis MAV6200AWW Washer agitates and spins. Water sometimes empties. Pump is fine spins freely and the impeller is fine. Could it be the belt ?
You will need to check for an article of clothing stuck between the basket and tub that may be partially blocking the drain hole.
Nov 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Have checked all recomended trouble shooting suggestions- there must be more?ot drain or spin, motor running, all lines have free flow of water, nothing between tubs and pump pulley moves freely. can
although the pump will turn by hand . when you use the motor power and the belt tenson;. it may be binding. ( this has been a common problem. ) ck for play in pump shaft and look for black under washer from belt fraying . my guess is the pump and also replace belt with the pump // hope this helps. **** and thanks for using fix ya ..
May 04, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6250AWW won't rinse or spin?
clean motor rollers(belt may be slipping)
9vopy...paste)
Aug 31, 2009 | Maytag Atlantis MAV7260B Top Load Washer
I have a Maytag Atlantis MAVT754EWW machine and there is a black soot like substance being left on the floor under the washer. It smells like rubber - do I need to replace the belt and if so, how do I do...
this black soot like substance is the motor carbon brush dust. i would get the motor brushes replaced and clean off all the dust from the pulleys and also replace the belt as it has been slipping on the dust.
Mar 18, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My washer won't spin clothes. I
Typically the plastic pulley is worn down at the bottom of the machine if the motor runs and the unit does not spin. There is a pulley kit to replace it. Sort of hard to do; may want the reapir man. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Maytag Washing Machines
Maytag atlantis washer
Start by checking the belt by tilting the machine back and examining for wear, glazing and cracks, next pull the belt to make sure everything turns. Post back if this looks fine.
Jul 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Washer
Sound like you have something stuck in the pump check the hose going into from the tub
Jan 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
206 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
