Question about Dell VOSTRO SLIM TOWER and , MONITOR 19 inch Widescreen E198WFP Analog Flat Panel - Intel?® CoreTM2 ... PC Desktop
Monitor will not diplay, like it's in perment sleep mode. I have unpluged it tried new cables, I am out of ideas, HELP!!
  • 4,281 Answers
When you power up the computer press F8 key then enter in enable vga mode thne go to control panel and display property then change screen resolution to 1024*768 then check.But if you are not able to safe mode and other menu when you press F8 then follow below steps.1 by 1 and check.
First open cpu cabinet then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reattch ATX power connector to motherbord.
Reattch power cable and SATA or ide cable to harddisk.
Clean dust from all parts of motherbord.
Open processor fan and processor.
Then reattach both.
Make sure motherbord is not ground with cabinet.
Remove pci cards from motherbord then check.
Let me know if you need further assistance.Thanks.
Posted on Nov 13, 2009
When I turn monitor on it just says "No signal" and goes off. Help!
Power off the monitor.
Unplug the video cable from the monitor.
Power on the monitor.
You should get some sort of display on the monitor saying "no signal" or something similar as you have already experienced - if so, good.
This means that your monitor should be OK.
Next, power off the monitor again.
Plugin the video cable back into the monitor, make sure you screw it in all the way.
Unplug the video cable from the back of your computer, inspect if for any damage.
Plug the video cable back into the computer, make sure you screw it in all the way.
Power the monitor on.
Any picture?
No? Make sure the computer is turned on and is not in any sleep or hibernation mode.
Still no picture?
Try the monitor with the same cable on another known working computer.
Still no picture (or you don't have another computer)?
Purchase a new video cable or swap video cables between monitors if you have another monitor.
Also make sure that the monitor cable is not crimped and it looks in good working order.
Jun 16, 2011 | Office Equipment & Supplies
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Sleeps and won't wake up. unblug pwr supply won't shut down properly. when pwr supply is plugged back in, monitor like comes on blue then amber like in sleep mode. Nothing shows on monitor. ctrl /alt/del...
Hello
Thank you for using FixYa for your problem
Needs a techie toolkit disc to run HDD regeneration scan then try the repair mode in your install disc, (2nd repair mode)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Feb 21, 2010 | Gateway GT5625E Refurbished Intel Desktop...
As soon as i turn on my computer the monitor goes into sleep mode
try another cable I have tis problem on mine & I have to do them up solid, also check for bent pins in the cable & bend the back carefully & unplugged.If not you may need to set up the computer to output, try another monitor to rule that out.
Hope this helps!
Sep 22, 2009 | HP Pavilion F1703 17" LCD Monitor
I want to permentely turn off degauss mode in my monitor
Do you have everything plugged into a surge protection power strip?   If not consider getting one, as this will eliminate the Voltage Spikes which may be caused by everything coming on at the same time.
Nov 15, 2008 | LG Flatron 776FM 17" CRT Monitor
Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Jun 17, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Sleep mode
Does the monitor go to sleep when you unplug the video cable? If so, then the computer is still sending a signal, if not, check the monitor menu settings for no signal settings.
Apr 25, 2008 | ViewSonic VX2435wm (Silver, Black) Monitor
Windows XP Pro 64-bit intermittantly wont come out of 'Sleep' mode or waken
Try turning off, and unplugging the monitor.
then replace the cable between monitor and pc.
if you still get no action, i,d suggest looking at the graphics card.
if it,s a pci card, try it in a different slot on the motherboard.
if it,s agp try an alternative card, if it,s onboard, try adding an additional card to the system, to see if that brings the monitor out of standby.
Mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
Iiyama vision master pro 450. Faulty auto switching??
hi,the problem is with the LCD electronics , you will need to get it repaired from the sevice center, when u power up the LCD its heating up something inside which is switching it off .
Dec 22, 2007 | iiyama AX3815U 15" LCD Monitor
Dell VOSTRO SLIM TOWER and , MONITOR 19 inch Widescreen E198WFP Analog Flat Panel - Intel?® CoreTM2 ...  PC Desktop Logo
159 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
