Settings too low
Connected this new monitor and it worked fine (without sound at that point). After installed driver from CD it set display at very low and all troubleshooters said to go into display monitors, advanced settings and properties to change default monitor - but can't click properties and can't find name of this monitor to set etc or software to uninstall! Can anyone help? (Yes, it's probably something stupid but driving me mad because causing other problems too now)
  • 2,229 Answers
Right-click on your desktop. You are not going to look for a "monitor" but you're going to be looking for "display properties."
So, after you right click on the desktop, click on the properties and it should show you the resolution in the lower left of the window (assuming you're using XP) Vista and Windows 7 use "personalize"\."
Anyway, assuming the correct video drivers are installed, you can change the resolution within those menu items.
Posted on Nov 13, 2009
I have an ACER X233H that I purchased from Office Max around January. It's been working fine since then, then this morning when I turned my computer and monitor on, the resolution is very low, setting...
I do not believe it is the monitor problem, it is just dispalying what it being fed with, you can easily verify that by connecting it to another working PC. I believe the problem is with your video card. Did you install any new software or driver lately? You may want try reinstall the video driver to see if that will fix the problem. Or you can use the windows system restore point to take it back to the day before the problem happened.
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20X223W/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 28, 2011 | Acer 22" X223w LCD Monitor
Tip
How to install your monitor drivers in Windows 7 1. You will need to access your...
1. You will need to access your computers display settings. This link will show you how to access the display settings
http://www.fixya.com/support/r4290529-change_windows_7_display_settings
2. Click on "Advance Settings"
3. Click on the "Monitor" tab
Note here is where you will is if you have a generic drive installed or not. If it shows Generic or Plug & Play Monitor then you may not have the actual monitor drivers install.
4. Click on the "Properties" button and click on the "Driver" tab
5. Next you will want to click on Update Drive
At this point you will want to select "Browse my computer for the driver software". The reason you want to do this is because if you select "Search automatically for the updated driver software" you will most likely get the default Windows drivers that are already installed.
6. Next you will browse to the driver CD or the place you have the drivers saved on your computer. Note if you just upgraded from Windows XP your old drivers may not work and you will need to find Windows 7 versions of the drivers. However if you have a Windows Vista version of the driver this may work.
After you get the location set click Next
7. At this point you should get a message that states that the drives have been installed.
8. Click Close - Close - OK - OK and you should be back at screen resolution.
Other Helpful Links
How to change your Windows XP display settings
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
on Mar 08, 2010 | Computers & Internet
Rainbow colors on the display , comes in gradually and covers whole screen after booting up ok to windows desktop...cannot see past the pixils....
Hi, this sound like the resolution on the monitor is too (Low); go to: Contol Panel, click Display Settings. Ajust the resolution to the High position; also down-arrow Highest Colors: 32Bits etc. Thanks paul7of9
Jan 03, 2010 | Dell Inspiron 530 Desktop Computer
Monitor (hp w1907)
Pls power on your PC & press F8 button continously then you see last known good configuration option. select your option & press enter. i hope your problem will be solved.
Nov 13, 2009 | HP w1907 LCD Monitor
Toshiba Satellite A100 PSAA2C video boot
have you tried installing or running the drivers disc for your laptop right after the windows installation without restarting it first? that might do the trick... it's either the driver for your laptop's board/ chipset or the vga driver...
Nov 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
Monitor receiving signal, but no image
Hello!
I see many monitor with that trouble.
When you turn on comp., you can have a picture on monitor about 10-30 min. and that go in black screen, or If you change resolution again go in black screen.
You must repair monitor or bay another.
Nov 02, 2009 | Acer AL2416W Monitor
Screen will not display
Have you ensured that your display card driver AND correct monitor driver is installed. This is to make sure that your display card only generates signals that your Acer monitor is capable of handling. If you do not have the driver CD for your monitor you can download the software from www.acer.com. The problem is most likely that your display card is generating a refresh rate which your monitor cant handle. Go to your display properties and lower the refresh rate of your display card and see if this solves the problem.
Best wishes,
Graemevm
Jun 29, 2009 | Acer H233H bmid Monitor
LCD Monitor stays on 4 bit resolutionm
Its your VGA card that's having issues with the LCD display. Try reinstalling the VGA drivers see if it works.
Jan 22, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Monitor doesn't stay on.
Your problem seems to point to your video card. Your video card needs a driver to function. Odds are good that you need to install a video card. Avoid using the built-in Windows driver. A new video card has a CD with it. Use that. With your driver installed, configure your display settings. The Display applet on the Control Panel is your next step. The Display applet provides a convenient central location for all of your display settings. Go there and make your setting using the tabs.
You can crash Windows and force a reinstall simply by installing a new video card and not uninstalling the old card's drivers. Always uninstall the old card's drivers before you install drivers for a new card.
Mar 17, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
