Question about Brother HL 1250 Laser Printer
Printed paper is stalling within the output.
My printer _ Brother HL 1250 performed well for 3 years. Two days ago it started blocking a paper by the two rollers at the output. The printer stops and displays paper alarm.
. The deformed paper stays compressed before the rollers and cannot be removed (reached). I feel that changing the distance of the rollers could fix this problem (?). How can I do it?
Thanks for your help,
Miloslav Kabat
    President:
  • 2,306 Answers
That's a common problem on that machine, those rollers at the exit get coated with toner and fuser oil, so they have no grip to pull the paper thru. If you dampen a rag with alcohol and power off the printer, each time you turn it on or close the front door the rollers turn and you hold the damp rag against the exit rollers one at a time to clean them...
Posted on Nov 13, 2009
Brother HL 1250 Laser Printer Alarm light blinks at same time as ready light and printer does not print - why?
I have saeen this happen and there is usually a paper jam somewhere in the machine. Remember, it doesn't take much of a piece of paper to jam. Use a flashlight and look inside your printer closely. Also check your toner supply level.
Oct 02, 2010 | Brother HL 1250 Laser Printer
How can I check the count of pages printed in my brother hl-2140 printer ?
Turn the printer off then on, wait a few secondes then press the GO button 3 times quickly.
The printer settings will print. It will show you how many pages have been printed as well as number of paper jams and errors etc.
Jun 11, 2010 | Brother HL 2140 Laser Printer
The printed pages have a black lines that block out words or images printed under the black lines. I am using a friends Brother HL-5270 lazor printer, she has lost the manual. Six months ago, I took the...
The inside could be dirty, blowing it out could help, but first try taking out the toner and drum and cleaning the corona by running the blue tab near the front back and forth about 20 times and then blow out that area with a can of air. If you can see the lines on the drum, you may need a new drum.
Sep 17, 2009 | Brother HL-5270DN Laser Printer
Hl-2140 noises
For a possible fix to the Brother HL-2140 squeal/squeak/noise problem open the printer at the other side from the paper tray and toner cartridge door. You should see a little black roller rod along with some white wheels.
The noise may be coming from the contact between the wheels/rollers which pull paper toward the output tray on top after it has been printed.
Check and clean/wipe the wheels and black rod, especially in the center area. Hopefully the noise will now be reduced/eliminated.
Cheers, Stephen
Sep 14, 2009 | Brother HL 2140 Laser Printer
Brother HL-5250dnt - Clicking Noise and not picking up paper
You may have to use a true Brother toner cartridge as I have the same problem with me MFC 8500. If I use a compatible cartridge it clicks and if I use a geniune Brothr cartridge it does. Brother direct brought this to my attention.
Apr 06, 2009 | Brother HL-5250dnt Laser Printer
Black track on the printed papers
Bad drum
(or sometimes: a little part of a previously jammed paper that blocks access of the laser beam to the drum)
Apr 06, 2009 | Brother HL-6050DN Laser Printer
Brother HL2070N printed 1 page fine,then nothing but light streak
turn off printer, remove cartridge and drum and clean internally.
reinstall drum and cartridge and do a test print, hopefully all will be better.
Jan 18, 2009 | Brother HL-2070N Laser Printer
Blank white 'line' on printed output
Some of the brother printer use a toner cartridge that does not have a drum, have u replaced the drum recently, or does the toner cartridge have it installed? If it has a seperate crriage for the drum, let me know.
Dec 11, 2008 | Brother HL 5140 Laser Printer
HL-2070N paper LEd flashing
most likely a sensor is tripped, eiher it's stuck or there is something blocking it. the most likely place is in the fuser, back door where paper exits and geta hot. look closely you should see a black lever towards the middle of the fuser, it should be up
Oct 18, 2008 | Brother HL-2070N Laser Printer
Brother HL 1250 Laser Printer Logo
192 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
