Replacements for my computer
Where can I get qet a replacement or compatible upgrade for my Dell dimension XPS 400/9150. I've looked on line a can't find one. I also couldn't find an exact power supply. I had 375. I bought an antec 500 because it looked the closest. I'm waiting for my son to come over and try to install it. any suggestions? thank you.
  • 4,806 Answers
Dell uses specialized power supplies for their desktop systems.
Standard power supplies won't fit in the case unless you modify the case (which is something you don't really want to do)
Take a look here at an OEM Dell power supply >>>>>>>>>>>>
http://www.discountelectronics.com/index.php?l=product_detail&p=2682
Regards.
Posted on Nov 13, 2009
What is the maximum ram capacity of dimension 8200 motherboard
2 gygabytoes are usually the max, you could upgrade the OS to maybe Windows XP 64 bit, but this isn't worth it in such an olde machine! Throw it out and get yourself an ASUS laptop with Windows 7 64-bit, a solid state HD and 4 or more gigabytes of ram instead!.
http://www.crucial.com/upgrade/Dell-memory/Dimension+%2F+Dimension+XPS/Dimension+8200+Series+%28400MHz+FSB%29-upgrades.html
Mar 16, 2013 | Dell Dimension 8200 AUD System Board...
I put the memory stick in my dell but the computer does not upload the device. so I went to control panel in devices and printers and I can see the devices but when i say add to this computer it's
Memory sticks are not devices such as printers and
Dell XPS 400 PC Desktop
Installing RAM on a desktop computer is of moderate difficulty for most non-technical people. Before beginning any memory upgrade, make sure the proper RAM has been purchased. The Dell XPS 400 requires DDR2 RAM (240-pin DIMM).
Preparing the Computer b> The computer must be unplugged before any work can be completed and the proper precautions must be taken, such as wearing an anti-static wristband. Also, replacing the RAM on a Dell machine could void its warranty. To install the new RAM, the case of the computer needs to be opened. Replacing the RAM b> The motherboard has four RAM slots. Each slot takes one stick of RAM (up to 1 GB per stick). The XPS 400 can utilize up to 4 GB of RAM. If adding RAM, put the new RAM in an empty slot. If replacing the RAM, take out the existing one and then put the new RAM into the machine. Important Notes b> While the Dell XPS 400 has four RAM slots, if only two sticks of RAM are to be used, they must be inserted into slots 1 and 3 or slots 2 and 4 for optimal performance. A single stick of RAM should be inserted into slot 1. Always put the largest ram module closest the CPU central processing unit.
Start your computer Wait for Windows to load. Click on "My Computer" and select "Properties" using right-click in the Explorer window. This will open "Systems Properties." Click on the "General" tab. Here you can view the physical memory installed on your computer. The amount indicated is the total RAM installed on your computer. RAM is usually 32 MB, 64 MB or 128 MB in older PC versions. Newer PCs are usually equipped with 256 MB, 512 MB or even higher RAM.
b>If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system. You should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible.
Mar 01, 2013 | Dell XPS 400 PC Desktop
Need new video card for dell U2424 motherboard
What is the Dell model? XPS-G2? This is a Laptop?
Jan 17, 2013 | Computers & Internet
How do I replace the motherboard in a dell xps gen 4
You will have to go to the Dell website and create an account. Here you can download manuals for you product line. I've replaced motherboards on that model before, not easy.
http://www.dell.com/support/home/us/en/19/product-support/product/dimension-g4/manuals
Jan 12, 2012 | Dell Dimension XPS Gen 4 PC Desktop
I need to replace the battery on my Dell dimension XPS gen 4 computer. Where is the battery and what type of battery is used for replacement?
the battery is located on the motherboard it will look like a giant hearing aid battery remove the battery and go to your local pc shop or even best buy and they will have the right battery for you. Make sure you unplug the computer prior to opening it up
Apr 14, 2011 | Dell Dimension XPS Gen 4 PC Desktop
Need to replace the CD/DVD combo. It will not
Any SATA DVD combo should work they are all industry standards.
Jan 26, 2010 | Dell Dimension XPS PC Desktop
I have a Dell dimension XPS 400/9150, 3 years old. I did updates and shut down. Tried to restart, but all I got was a flickering amber light. Won't start at all. Now no light.
Sounds like your power supply just failed. Unplug the power cord, open the case, and look for a metal box inside the case right where the power wire plugs in. Remove the box...usually four screws hold it to the case, remove all of the wires...marking each one and the motherboard so you'll be able to connect the new power supply wires. Most computer stores will have a suitable replacement. Easy replacement if you mark the wires/connections during removal. Just be sure to work with the power plug removed.
Nov 12, 2009 | Dell Dimension XPS PC Desktop
Dell Dimension XPS GEN 5 IDE Philips CD DVD drive failed. So I tried a Liteon SATA CD DVD drive, but that wouldn't work. So I tried a Samsung IDE CD DVD drive and that won't work. I'm guessing mobo driver...
first try installing one and go to your bios and set your bios to default . save you changes and exit.
also in my computer look and see if it appears there
if so you know its being reconized.
rite click it go to properties and then hardware
select the drive if you have gotten this far meaning you saw the drive. . go to properties and see if it says its working properly. it could also be that none of the drives your trying to install are compatible.
Nov 12, 2009 | Dell Dimension XPS 400 PC Desktop
Compatibility
Not without major case modifications. Dell uses Dell specific rather than industry standard motherboards on all their systems except the newest XPS line. Sorry.
Feb 24, 2009 | Dell Dimension 9100 PC Desktop
Hard Drive Upgrade on Dell Dimention 5100 Desktop
are you replacing it, or simply adding one to your desktop?
best place to get that information is www.dell.com
click on accessories
Feb 27, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
