FixYa.com
Tags:
Sony CMT-CP505MD CD Shelf System
Sony cmt cp505md has some sort of power problem
posted by jmackie on Mar 22, 2008
on stand by it lights up but when i turn it on it comes on for a second and then goes out can you help
it looks like the fan is not kicking in
Comment by jmackie, posted on Mar 07, 2008
my sony cmt cp505md has some sort of power problem, from standby it look okay, when powered up it lights and the trips out. some times it will stay on and work but the fan is not going round. but i've tested the fan and it works fine. and i can't fined free circuit diagrams please help
Comment by jmackie, posted on Apr 19, 2008
i know it has a fault,this site is called fixya and (you must have a degree to give that reply) it has a fault!! fault!! fault!!
do you think the mouse that keeps it running has died
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Mar 22, 2008
Thanks for Trying (70)
robotek
Rank:Guru Guru
Rating: 90%, 505 votes
Hi there, the unit may be going into protection mode. This can be caused by many things, but the first thing to check for is dry solder joints
Comment by robotek, posted on Mar 22, 2008
If you have the unit in pieces, I would start checking about power stages, and any devices that are mounted to heatsinks for cracked or dry solder joints. It may take some time to do this, but is the only correct way to approach your problem. I am trying to find you a cct diag. Back to you soon
regards
Graeme
Comment by robotek, posted on Apr 19, 2008
A cooling fan in audio gear does often do not operate until temps get to the point that they are required to. After having given you initial advice, I can only take from your feedback to me, that you have not been able to carry out even the most simple rudiments of fault finding by visually checking for dry solder joints in the output and power supply stages?
There are many things to check, I have also not been able to get a circuit diagram for you for free. You will have to pay for one.
It is understood that you have a fault!! Diagnosis of that fault is what you are asking for from FixYa. We can only give you advice. You need to then do the work!!
If you do not have any prior knowledge of analogue power supply circuits, audio output stages, or microproc control circuits, then you may need to take the unit to a repair man like myself in your area.
So good luck with that one mate!!
Comment by robotek, posted on Apr 29, 2008
I read from your rejection of all good advice offered thus far, that you are expecting someone from somewhere to tell you where the button is that will reset the fault condition for you....... and if no one can tell you where this magic button is, then you should not have to pay for the advice given. The solution that I offered is on track, however, you have declared that you believe it is incorrect, and you are still looking for some magic! As this is the third time around you have rejected good advice... you should get you money back right. Well then, maybe as you have so wisely suggested.... you perhaps DO have a rodent problem!!
Rating Locked! (?) jmackie has rated this solution as Thanks for Trying
Solution #2
Not Rated (0)
Abrsvcs
Rank:Guru Guru
Rating: 86%, 590 votes
Hopefully better late then never, let me describe what is going on here. First, tehse shelf units attempt to get to a know condition everytime they power up. This means that you should here the CD spin and the cassette motors run. I believe that your model (I'd have to look itup to be sure) has either 3 or 5 CD storage inside which means that the whole CD mechanism also attempts to get to a known condition. Should any of these attempts fail, the unit will shutdown to prevent further damage.
The other posters are correct in that Sony does not make service manuals available to the consumer without cost. Authorized service centers pay a subscription every year to gain access to these manuals electronically and are prevented by contract from sending them to anyone.
That being said, the most common fault for these shelf systems in mhy personal experience has been the CD changer/loader that gets out of timing. This requires a rebuild of the mechanism that is relatively simple with the manual and some prior experience. Problems with the output amplifier section can also cause this. The amp problem is easily detected by taking voltage readings during the startup process.
I hope this has helped you to understand the situation better.
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
Not Rated (0)
IB4G2008
Rank:Wiz Wiz
Rating: 81%, 1684 votes
jmackie,
Sony is one of those companies that keeps their information tightly wrapped, so the chances of finding a free service manual are quite remote. The answers here are fair, balanced and accurate. The suggestion to take the unit to a Sony service center is consistent with my own experiences, as well.
I hope you find resolution to this issue.
Solution #4
posted on Apr 15, 2008
Not Rated (0)
Ekse
Rank:Guru Guru
Rating: 86%, 1230 votes
Its clearly a hardware fault, parts might need to be relaced. if you still have warranty contact your dealer.
About the repairs, contact a local electronics professional for advice and repairs.
Or sony.
Comment by Ekse, posted on Apr 15, 2008
Fixya is haveing a email system problem, you might not get notifyed about my solution untill it is fixed.
Comment by Ekse, posted on Apr 19, 2008
check the powersupply and mainboard for bulky capasitors. and other components witch look bad.
Solution #5
Not Rated (0)
micromaster
Rank:Wiz Wiz
Rating: 79%, 237 votes
check for the burn fuse on the powersupply area..
Solution #6
coolguy008
Rank:Wiz Wiz
Rating: 85%, 229 votes
HI,
Since the service manula is not availabel for free,you can buy the service manual from HERE
You can view the user manual fromHERE
Goodluck,
Please don't forget to rate the solution.
Can you Help with these Audio Shelf Systems problems?
Audio Shelf Systems
lost guide for remote control
have lost guide for my extra... Answer This...
Audio Shelf Systems
Cant get the Unit to respond to...
Hi In moving house i lost the... Answer This...
i have a sony cmt cp 505md with...
i have posted my problem... Answer This...
power on fails
it lights in standby but when i... Answer This...
power circuit cmt cp505md
it powers on for a second and... Answer This...
Repair Service
Find Audio Shelf System Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
