Question about True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC
GDM-49 We've searched the fridge and there doesn't appear to be a starter cap at the bottom or top receptical for the light. It is an older GDM-49 and the light is located between the two doors. Is there any way that the starter cap could be located anywhere else? We also didn't see a ballast in the base. Any guidance on finding and/or replacing the ballast, if that is what is causing the flickering problem. Thanks!!!!!!
  • True Master
  • 1,250 Answers
Http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
Go to the above web site. It should be the installation manual for your unit. It has lots of good stuff.
Hope this helps
Posted on Nov 20, 2009
True commercial cooler model GDM-49-LD. Been fine for several years. Water now accumulating in cooler floor. Origin seems to be back wall dead center. Any suggestions ?
drain tube runs from dead center of the coil into the back wall and down under the unit where it drains into a pan and is evaporated. Sounds like just a blocked drain tube. The easiest way to clear this is to take the bottom front grill off and look for the drain tube which is typically just strapped to the top of the opening suspended over the pan. Use a wet vac to pull out the sludge or some kind of pressure to blow it back up into the cabinet. Problem with blowing back is that dirt and water are going to blow into the cabinet and/or coil. taking the hose off of the interior coil is difficult and you can break the plastic connector so I don't recommend that to anyone.
Sep 04, 2014 | True 49 cu. ft. / 1388 liter Commercial...
Product in my true gdm-49f freezer is frosting up and there is an ice build up around the inside of the case. what could be the causes of this.
Try defrosting the unit by shutting it down until all ice is gone. If this corrects the problem and the ice returns you may either have a defrosting problem or a low freon charge.
Jan 20, 2011 | True 49 cu. ft. / 1388 liter Commercial...
How much open space should I provide around my True freezer?
This unit pulls air in through the lower louvers in the front and pushes the air out through the back . It produces a lot of heat when running. 3 or 4 inches at the back should be sufficient if the air can escape over the top of the freezer.
Sep 23, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Have a gdn-49 true freezer freezing in evap to compressor what could be the problems
low refrigerant, leak, evap fan inop, thermostat inop.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2010 | True 49 cu. ft. / 1388 liter Commercial...
T-49F freezer cant get bellow 25
cap tube/ has unit been serviced before/ if you know it has correct charge compressor may have failed easy fix. expansion valve or cap tube maybe another thing to check i always remove entire charge get a good micron reading put exact charge back in if wont pull down comp. likelly
Jan 18, 2010 | True 49 cu. ft. / 1388 liter Commercial...
Timeclock Not going in defrost
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
Go to this web site and check out the owners manual. On pages 13 or 14, it discusses the time clock. If the time clock is not moving to begin a defrost cycle, I would say, replace it. It does have a mechanical motor and it can fail or lock up.
Hope this helps.
Dec 13, 2009 | True 49 cu. ft. / 1388 liter Commercial...
TRUE freezer model number GDM-49F.
Your unit should have a defrost timer.The timer may be stuck in a defrost.It should be located at the bottom of the unit next to the compressor.Open the door to the timer and observe the position of the timer.If you turn the knob and the unit starts up,it's the timer. If this is the case, you can purchase a new one at any local a/c supply.Let me know,Mike
Dec 13, 2007 | True 49 cu. ft. / 1388 liter Commercial...
True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC Logo
280 people viewed this question
Top True Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a True Freezer Expert? Answer questions, earn points and help others
