Question about Gigabyte GA-8IDXH Motherboard
Dos compatibility Is intel 945 chipset compatible for dos based programs. I face errors while running dos based application written in foxpro.
  • Anonymous Mar 26, 2014
    foxpro 2.6 for Dos single user programs want to use local Area Network environment
    Problem Solver:
  • 19 Answers
Yes intel 945 chipset is not proper work on Dos based programs.u can use foxpro for window
Posted on Jan 09, 2008
I am using dos based foxpro application in widows xp. when ever i take print from epson Fx 2175. the print job is paused at last line until i close the application. please rectify.clarify,...
Many DOS programs were designed to write directly to the printer's buffer, rather than to a spooler like more modern applications. It sounds like FoxPro is doing exactly that - and isn't designed to release the job until being completely closed.
Mar 06, 2011 | Epson FX 2170 Matrix Printer
I HAVE 20 COMPUTERS CONNECTED THROUGH LAN SYSTEM HAVING XP SERVICE PACK 2 & 3 OS. I HAVE INSTALLED NORTON 2010 ANTIVIRUS SOFTWARE ON EACH SYSTEM 10-11 MONTHS BACK. I HAVE ERP-SYSTEM IN FOXPRO FOR DOS...
Dear Walia,
We need to check weather you are getting any error message while trying to access the Network Computers..
Could you please go through the following steps and check weather you are getting any error message or Dos system getting hanged..
Disable the Norton program from the First 2 systems and try to access the Computers with Ping command...
To use the ping command please open the Command prompt and type ping [ip address of the Second system] ...
If u can access the Computers after disable the Norton program means surely it due to the issue with the Norton firewall...
In that case we need to create the New firewall rule for the Norton program to access the Specific Application
Thanks
Alexander Xavier
Nov 30, 2010 | Norton Internet Security 2010 Antivirus +...
What is intel(R) matrix storage manager
Yes you need it. document.write("The files below contain the Intel® Matrix Storage Manager.
This driver provides support for high-capacity & fault-tolerant Serial ATA (SATA) RAID 5 arrays and high-performance & fault-tolerant SATA RAID 10 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X and 945 chipset-based platforms. It provides support for high-performance SATA RAID 0 arrays & redundant SATA RAID 1 arrays on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925, 915 chipset-based platforms. It also provides AHCI support on select Intel® 5 Series, 4 Series, 3 Series, 965, 975X, 955X, 945, 925 and 915 chipset-based platforms, as well as on Mobile Intel® 915/910 chipset-based platforms.
Note: Intel® RAID Technology requires the Intel® ICH9R/ICH9M-E/ICH10R/PCH/PCHM SATA RAID controller hub, Intel® 82801HR I/O controller hub (ICH8R), Intel® 631xESB/632xESB I/O controller hub, Intel® 82801GR/GH I/O controller hub (ICH7R/DH), Intel® 82801FR I/O controller hub (ICH6R).
DISCLAIMER: This software is provided by Intel only for the convenience of its customers. THIS SOFTWARE IS PROVIDED \"AS IS\" WITH NO WARRANTIES WHATSOEVER, INCLUDING ANY WARRANTY OF MERCHANTABILITY, NON-INFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, OR ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. This software is furnished under license and may only be used or copied in accordance with the terms of the license. The software is subject to change without notice. Intel assumes no responsibility or liability for any errors, incompatibility issues, inoperability or inaccuracies that may appear in this software.
See the Installation Instructions page for a list of system requirements and considerations.
Note: Before installing this application or requesting technical support from Intel, it is suggested that you first contact your system manufacturer. They may provide software which is specifically configured for your system.")The Intel® Matrix Storage Manager.
So don't delete it.
Mar 10, 2010 | Computers & Internet
Transfer foxfro dos-dased attendance application to other PC
well the good news because it dos based, it should be very self contained for example if the program is in a folder called foxapp, copy this folder and sub folders and all contents to the new machine,
if it don't work you missed something , just a case of having a look at other folder names most fox apps I wrote were contained within it own folder.
Regards
GeWiz.
Jun 04, 2009 | Microsoft Visual FoxPro 5.0 for PC
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Foxpro dos application exe obfuscation
you need the re-fox or fox shell
is works good
an from mexico
Jan 02, 2009 | Microsoft Visual FoxPro Professional...
Problems with Intel D946GZIS Motherboard
Hi pbkajey, This Asus board will easily handle your 3.4GHz CPU & fully supports 1600/1333/1066/800 MHz FSB.
Suggest this motherboard:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=4244469&SRCCODE=GOOGLEBASE&cm_mmc_o=TBBTkwCjCVyBpAgf%20mwzygtCjCVRqCjCVRq
The only catch is this board runs, DDR3 memory. Up to 16GB of Dual Channel memory.
Asus link for the P5Q3 MB:
http://usa.asus.com/products.aspx?l1=3&l2=11&l3=709&l4=0&model=2563&modelmenu=2
Review:
http://techreport.com/articles.x/14655
Asus comes with an impressive three year warranty. Most manufactures support 1 year only.
Here is another Asus board that will run your CPU & DDR2 memory:
http://usa.asus.com/products.aspx?l1=3&l2=11&l3=709&l4=0&model=2581&modelmenu=2
Same 3 year warranty. There are two boards that support the 945 chipset below:
http://www.asus.com/products.aspx?l1=3&l2=11&l3=707
Keep in mind you do not have to keep the 945 chipset. The newer boards still support 945 & better.
The choice is your's.
Good luck pbkajey!
More question? Post here.
Mike
Nov 19, 2008 | Intel D946GZIS Motherboard
Re aspire 7104 being upgraded to duo core processor
No it cant be updated
Your acer aspire is based on the 910GML chipset
The Mobile Intel® 910GML Express chipset is optimized for the Intel® Celeron® M processor.
Here you can compare the 910gml chipset and 945 which is used by the core 2 duo.
http://compare.intel.com/pcc/showchart.aspx?mmID=22210,7419&familyID=7&culture=en-US
As you can see on the page there are key difrences between the chipsets other runs on ddr2, yours on ddr. the FSB support is 400 on yours and 533 / 667 on the 945.
also you can see the supported processor familys right there.
you can look for a
Intel® Celeron® M processor,
Intel® Celeron® M processor Ultra Low Voltage (ULV)
Upgrade cpu with maximum FSB of 400MHz
Apr 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Gigabyte GA-8IDXH Motherboard Logo
100 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
