Question about Ricoh 4420L Printer
I have a new computer and cannot use the plug to link my computer to the printer. Is there a way to change from a parallel port on the printer to a USB? The printer is about 3 years old, Ricoh 4420L
    Brigadier General:
  • 10,406 Answers
Instead, buy an add-in PCI card, which adds a parallel-port connector to your computer. About $20.
Posted on Nov 13, 2009
Testimonial: "Thank you!"
Don't know how to connect HL-2040 printer to laptop.
If the printer does not have a USB port and the computer does not have a parallel port then you will need to get a USB to Parallel print adapter. One end is USB to plug into the computer and the other end has a standard parallel port to plug into the printer. Install instructions will come with the adapter. Try any computer shop such as Best Buy, Radio Shack, etc etc.
Apr 24, 2011 | Brother HL-2040 Laser Printer
Printer is not detected by the computer after connecting the printer to the computer.I have installed the printer driver but still there is no respond from either the computer or the copier
Please change the USB cable and plug it to another USB Port on your computer and restart the computer.
Make sure that printer is ON while re-starting computer.
Mar 21, 2010 | Toshiba E-Studio 160 All-In-One Laser...
Is it possible to connect an old, still very efficient HP 5L Laserjet Printer which uses parellel port cable to a new computer via a USB cable? If yes, what do I need?
Yes it is. You just need a Parallel to USB adapter. Here is a link to an example of what you need.
Parallel to USB
I have done this several times with Parallel Receipt Printers. Works Great!!
Another option would be to add a Parallel Port to your new computer. Here is another link.
PCI Parallel Card
The 1st option is probably the cheapest and easiest.
Good luck and have a great day!
Feb 26, 2010 | Office Equipment & Supplies
Can the P2055d be connected with a parallel lead?
Most HP's if they have a port for parallel, it is a special plug on the back that looks more like a SCSI plug. If your printer has this plug you need the special cable, otherwise you will need an adapter to convert USB to parallel.
Dec 28, 2009 | HP LaserJet P2055d Printer
Bought new computer - no parallel port. bought
got to printer and faxes left click your printer and select properties then click "port" tab now look for USB and check mark it click aply and then close then try to print :)
Sep 23, 2009 | HP LaserJet 6mp Printer
Connect printer to PC
Dear! It is very to solve that matter use the USB converter for that solution and you can purchase a PC USB slot for that solution.
Thank You
Jul 27, 2009 | Epson LX-300 Matrix Printer
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
Mar 25, 2009 | Panasonic Computers & Internet
Konica Minolta 2300 dl is "printing to file"
The port depends on where you've connected the cable between printer and computer.
If a USB connection, select USB
if parallel cable, select parallel
if network cable (ethernet) select tcp/ip port
the driver must match the type of connection (use only 1)
you may wish to uninstall the printer driver then re-install it, keeping in mind which physical connection you have chosen to use.
Oct 25, 2008 | Konica Minolta magicolor 2300DL Laser...
My printer doesn't have the usb to connect it to the computer - what do i need to do?
If the printer does not have the square USB connector (USB B end), then it will have parallel. Parallel is a wide connector that plugs in to a DB25 connector on the back of your computer. These parallel port printer cables can still be picked up at just about any office supply or computer store.
What if your computer does not have the DB25 parallel port but the printer does? Well there are USB to Parallel Port adapters made specifically for this scenario. They can run $10 to $30 depending on where you go. I recomend www.Geeks.com for those. That will allow you to plug an older printer in to a newer machine.
If it's made for a mac only, there should be a small circular port about the same size as a PS/2 keyboard or mouse. That is to connect to the Mac serial bus. This is differant than the barrel connector or brick used to supply power to the printer.
Hope this helps.
Oct 16, 2008 | Lexmark Office Equipment & Supplies
Ricoh 4420L Printer Logo
66 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
