Question about Kenmore Oasis HE 27082 Top Load Washer
My clothes have a musty smell after being washed
  • 4 Answers
Along with the other solutions using bleach, leave the lid or door open between uses to let it air out.
Also, I find that if I have not used the machine for a couple of days, to get the stale water out of the bottom,[floating tub] I just run an empty, warm rinse/drain & low spin cycle. This also helps to keep any soap from building up inside.
I also frequently run the "clean washer" cycle, even without bleach, especially when I am going from running a black load to a white load or if I have washed the house cleaning towels or rugs.
This seems to help because I have never had a musty smell on my clothes.
Posted on Nov 30, 2009
  • 3 Answers
Just bought our machinembut was told if we didnt use the efficency soap.it would cause a musty build up of soap in the machine...
Posted on Nov 25, 2009
    Top Expert:
  • Kenmore Master
  • 76,846 Answers
Run a wash load (no clothes) with 2 cups of Clorox brand bleach and use hot water, that should help.
Posted on Nov 13, 2009
    President:
  • 1,653 Answers
Make sure there are no leaks from the machine. Look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose and door rubber is completely clear of debris and soap scum build up and check that the filter is clean.
You can initially use a bathroom mould and bacteria cleaner to get rid of the immediate problem or wash using a bleach solution made up from 1 part household bleach to 10 parts water. Place this in an aerosol spray bottle and spray the affected area and leave for 10 mins then wipe away and rinse with clean water.
  1. To keep the machine clean of waste or mould build up and to keep any bad odours away
  2. Remove all items from the washer.
  3. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
  4. Close the washer door and dispenser drawer.
  5. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
  6. Press Start and allow cycle to complete.
  7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
  8. Repeat the cleaning procedure monthly
SOURCE: Our Clothes smell musty and the washer smells too
I checked the whirlpool web site and typed in "musty washer" for a search of the site. They gave directions on how to run a cleaning cycle on the machine (whether your washer has a special button for it or not) This REALLY helped my machine. They also had trouble shooting tips for keeping the musty smell away.
Posted on Oct 08, 2008
SOURCE: Musty smell in washer
We had the same smell. It was so bad you could smell it when you came into the house. We switched to powdered detergent and the smell went away. If you put your nose down by the rubber seal you can smell it a little, but I consider the problem fixed!
Posted on Oct 25, 2008
  • 43 Answers
SOURCE: washing machine does not always take the conditioner
take out the soap draw and try giving it all a good scrub mith a tooth brush if that doesent work it could be problem with tap in the back bosch machines are always worth repairing though exellent peice of kit
Posted on Nov 11, 2008
aborcass
  • 2651 Answers
SOURCE: Clothes smell musty like wet towels after washed and dried.
check your detergent you are using, it should be a HE detegrent for High Efficency machines, too much regular detergent will suds up and nver be removed from clothing causing such a smell.a quick test to see if your using too much detergent, grab a sock form oyour drawer(clean one) place it in a glass of water and swish it up and dowen a few times, if soapy bubble wateris present then youre over soaping!
Posted on Jan 21, 2009
didik23
  • 35 Answers
SOURCE: it makes my clothes smell really bad
clean the filter.... after using the washer make sure u rinse it thoroughly with clean water
Posted on Jul 19, 2009
Washing machine smells musty
there is dirty water still in the m/c do a boil wash with nothing in it buy some nice smelling conditiner and poor some of that in it also this is a tip from my mam leave the door open when not in use to let the insides dry out
Aug 24, 2012 | Kenmore Washing Machines
How do we clean with this machine .
Is this a front-load washer or top load?
Is the machine operating properly, or are your clothes getting a musty smell?
The musty smell has a few solutions, One may work but probably a combination of all will work best.
Immediately move wet clothes to the dryer, do not let them sit in the washer for a long time.
If your clothes smell, put mouthwash with your clothes directly in the tub during the wash cycle (this will not stain your clothes)
leave the door open when not in use (lets it dry out)
If the washer smells, use bleach and hot water in an empty cycle once in a while (kills just about every kind of bacteria or mold which may be causing the smell)
Use washing machine cleaner once in a while(can be found at your local grocery store isle next to detergent)
Dry your clothes completely, damp clothes can start to smell again.
If you are looking for a new washer, try to find a newer model that features a stainless steel tub with silver impregnation. The silver is a natural disinfectant.
Mar 15, 2012 | Washing Machines
I have a musty odor after my clothes are washed. What's the problem. I clean my machine monthly with bleach.
I use 20 mule team borax and leave the door open when not in use and have no more musty smell in washer or clothes.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Smell after drying
Try drying your clothes without the dryer sheet and see if the smell is still there. If it is not, then the problem is the dryer sheet.
If it is, then you need to describe the smell better. Different people handle smells differently. What smells musty to you may smell fragrant to others.
You need to determine if the smell you don't like is really a musty smell, or is it a fragrance you don't like. Have some friends (not family members) smell the clothes and verify if what you are smelling is musty or fragrant.
It could also be that even though the clothes smell OK out of the washer, that the detergent you are using is the cause.
Dec 16, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Musty smell
Run your machine through its cycle with NO clothes and when it is filling up with water put bleach in the water. Put bleach in only at the start of cycle.
Before you do this clean all inside parts the best you can yes with bleach and you can run something like fleecy to make clothes soft and smell nice when you wash your clothes as well. Our machine has a special holder to put softener in.
Do NOT have clothes in when running the heavy bleach through it. This should kill the bacteria .
Aug 12, 2017 | Maytag ATW4475TQ Washer
1994 Kenmore 90 series washer smells musty
Do a boil wash without clothes & detergents, with a cup of bicarbonate of soda in the soap drawer.
Mar 30, 2009 | Kenmore Washing Machines
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
clogged water screens , defective water level pressure switch , clogged drain, kinked drain hose ,. defective water pump , defective water tempeerture switch, damaged water valve solenoid , water inlet valve has an interal malfunction
Oct 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Clothes Smell Musty and Damp
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
Oct 28, 2007 | Hotpoint WMA30 Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
455 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
