My screen flickers constantly, making using the laptop very very irritating. It used to just be if I changed the angle of the screen, now it's all the time. I don't even have to touch the laptop for it to start flickering. How can I fix this?
    Problem Solver:
  • 18 Answers
That meens you have to change the laptop screen power board its a small circuit board behind the laptop screen
hope this can help you
if not just
tell your location
my be we can help you by visiting there to solve your problem
support@itindiasupportonline.com
Posted on Nov 13, 2009
HP Pavilion dv6 7040 TX Laptop screen on right hand upper corner turns dim and after some time becomes uniform
Being a led screen maybe one or more of them have gone bad
Or if you are lucky just a faulty lcd ribbon cable
Mar 25, 2014 | Computers & Internet
Help? My screen flickers constantly and is driving me bananas! When I adjust it to certain angle, it will stop for a bit, but then the next time I open it to use it....same deal. Everytime I'm trying to...
sounds like your screen may be earthing out some were.
iam sure if you press on the sides of the screen it stops.
make sure all the screws are fitting ok around the screen.tighten them up if thay need it,
somthing is lose some were on your screen.
one other thing it could be is what thay call the inverter that sits behind the screen is faulty.
Aug 11, 2013 | Microsoft HP Pavilion DV6276US Notebook PC
Flickering blue screen
it may be the ribbon cable that connects the monitor to the motherboard,constant openingand closing makes these come loose or break.
Mar 19, 2013 | HP Mini Computers & Internet
How do i stop flickering on my hp notepad screen
Hi, On thing you can try. Go into system settings and see if you can change the refresh cycle on the screen. Put it to a higher setting and click ok and exit out. Hope this work for you.
Mar 28, 2012 | HEWLETT-PACKARD Computers & Internet
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
Screen is flicking again and agin Model is ACER Travelmate 5730
If the screen flickers when the lid is moved, then it is most likely the LCD ribbon cable has a bad connection to the LCD controller board. If it flickers without lid movement, then it is probably the inverter module for the LCD, but if it flickers constantly and especially if there are white lines that stay constant accross the display, then it may be an overheating or failing GPU. Check the air vents on the unit and make sure that there is no blockage if the latter is the case.
Hope this Helps.
Gill
Sep 24, 2010 | Acer Computers & Internet
Screen Flickering on Acer Asipre 5050
could you confirm the OS installed onthe system.....
one of the solution is.....
click start->then click on control panel-> the power option(the main heading) ->click on change plan setting on the right side next to balanced option ->then click on change advanced power setting -> scroller down and check if you can find VGA ->change if from maximum battery performance to the maximum power performance..
close all the screen and check if the screen still flickers...if yes let me know to heko drivers for VGA adaptor
let me know if it help...
regards
Jan 13, 2010 | Acer Aspire 5050 Notebook
Flickering of the screen
just open the system and reseat the display cable...
Sep 20, 2009 | Acer Extensa 5420-5687 Notebook
Laptop screen constantly flickers and whites out
Your Bulb is DUE, you need to change it, Don't do it your self contains mercury. Your LCD is good IF you do not have bad PIXELS. This white and pink lines shows as pixel problem but it migth also short on LCD, if you placed something heavy on Laptop. You may remove and sent the LCD for repair or all laptop to tech.
You may also need to check inverter. I give service around the Country but it is up to you. My company name is JMC TECHS INC. Registered in Miami Florida. (Check SUNBIZ.com) jmctechinc@gmail if you like to contact me.
JMC
Aug 15, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
Computers & Internet Logo
301 people viewed this question
David Payne
David Payne
