Question about Hitachi (AU-160GBSATAHDHIT) 160 GB SATA Hard Drive
HITACHI 160GB INTERNAL HARD DRIVE 2.5" FORM FACTOR
Hello I bought the above hard drive for my laptop. I have a slop to add another hard drive in my laptop and I have all the relevent adapters as its a dell laptop. After instaling the second hard drive I rebooted and I got a black screen and 'My Documents' was open. After trying to fix this I got frustrated and took out the hard drive and had to do a system restore.
I have been told that I have to make the second hard drive a slave for it to work? can you help?
Jay
  • jaylatif Jan 08, 2008
    Its a 5400rpm SATA. Model no: HTS541616J9SA00 - 160gb. My Laptop is a Dell Vostro 1700.
    Hope this helps
  • 21 Answers
Post what kind of laptop you have. Also post the model of the hard drive you bought, is it SATA, IDE, or?
Craig
Posted on Jan 08, 2008
  • cbri Jan 08, 2008
    Look herehttp://www.hitachigst.com/hdd/support/5k...
    It looks like the 2 pins on the 4 block farthest from the cable need to be jumped (vertically). Look at the bottom picture of the above link.
I have western digital external hdd usb 2.0 and i have opened it now i want to connect it as internal hdd, its a sata drive inside when i opened the cover
The specific connection depends on the form factor the hard drive mechanism and the computer in which you want to install it. If it's a 3.5" drive and you want to put it in a laptop, forget it; it won't fit in there.
If you want to put a 3.5" drive in a desktop system, you need a SATA drive power connector from the power supply, a SATA data cable, and a SATA port on the motherboard or an expansion card. (note that you will probably not be able to boot from this drive if it is connected through an expansion card unless your computer's BIOS supports booting from a PCI device). It's also highly desirable to have an empty drive bay in which to to mount the unit.
If the hard drive has a 2.5" form factor (2.5" wide), and it is to go into a laptop, you will need the 2.5" hard drive adapter for your particular laptop (many manufacturers have a special cable or adapter for hard drives, although they should all fit the SATA interface. However, if your laptop is an older model designed for PATA IDE drives, the STAT drive will not be compatible.
To put a 2.5" SATA drive in a desktop computer, you need an adapter kit. This includes a 2.5" - 3.5" drive mounting bracket adapter and a cable adapter connector for 3.5" drive connections as described in the second paragraph above. Many computer parts merchants carry these.
Sep 21, 2014 | Computers & Internet
Dear sir I have laptop..hp 2530p. 12" inch
You can choose any brand of replacement disk (Western Digital, Hitachi, Seagate, or Toshiba), provided it conforms to these specifications :
- form factor : 2''5
- interface : SATA
- size : at least 120 Gb, if your disc was nearly full, or less, depending on your storage needs.
Any computer shop can provide you with that kind of spare part.
They can also install the OS on the disk, with the drivers for your specific HP model.
Aug 31, 2014 | Computers & Internet
Won' recognized my external hitachi z5k320
check data cable.
change use port and check the driver on any other PC.
if problem is same after doing so. check hard drive Cage. change driver Cage
Jul 14, 2014 | Hitachi 160GB Travelstar Z5K320 SATA 3Gbs...
Add second hard drive
There are three variants for this case: the mini-tower (which you say you don't have), the "Small Form Factor", and the "Ultra-Slim Desktop".
The "Small FOrm Factor" has an internal 3.5" bay that will support a second HDD.
Dec 10, 2013 | HP Compaq dc7100 PC Desktop
ATA Hitachi HTS547564A9E384 Drive has 117325064 bad sectors. Ubuntu says to backup all data and replace the disk. Im using an HP Laptop and this started happening only 2 weeks after i bought it. Its an...
I'd take it back right away, sounds like the hard drive is going. There are things you can do to try and fix it, but I'd take it right back and get the seller to fix it. It also could be that the drive has come loose but odds are the hard drive is going. So copy all data that's important to DVD and take it back and have them replace the hard drive.
Aug 16, 2011 | Hitachi Travelstar 5k750 Hts547564a9e384...
Can GX240 hold second hard drive
It depends of the form factor of your GX240, please see below:
Small Form Factor - you can not add a second hard drive.
Small Desktop - you can add, but you have to remove the CDROM drive.
Small Minitower - YES. you can add a 2nd hard disk.
Source:
http://support.dell.com/support/edocs/systems/opgx240/en/ug/specs.htm
Jan 24, 2011 | Dell OptiPlex GX240 PC Desktop
Need new laptop harddrive
Go to either bestbuy.com or compusa.com and look for the hard drive there. The hard drive will be cheaper going thru either of those places. Also check out pricewatch.com cause you can compare prices there. Also go thru google and check out the shopping results of the hard drive your looking for as well.
Lots of places to check and the hard drive will definitely be cheaper then going thru HP.
Jul 06, 2009 | Compaq Computers & Internet
Drivelock hdd bay password
Hi
This drive may have been used before and may have had a password set on it. If it is new take it back and exchange it
Cheers
David
Jun 21, 2009 | Western Digital Scorpio 160GB Internal...
Replace existing 40GB internal HDD in laptop with 160GB internal
Drag and drop the files from one drive to the other.
  1. Plug your new drive in
  2. Right click 'my computer'
  3. than open 'C drive'
  4. repeat steps one and two
  5. than drag the files from C' drive to new drive'
Jan 05, 2009 | Computers & Internet
Will the hitachi 500gb internal laptop drive fit my hp pavillion dv9000 hope you can help thank you.
Yes, as long as it is a "laptop/Notebook" drive, the 2 1/2 inch form factor.
Nov 14, 2008 | Computers & Internet
Hitachi (AU-160GBSATAHDHIT) 160 GB SATA Hard Drive Logo
444 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
