Question about Toshiba B-SV4D Label Printer
Our labels creep in the printer so the get out of sync with the printing and slip onto the next label. Our labels are not on a roll but concertinad in a box fronm which they are pulled forward. I s this right or should the labels be on a roll. many thanks
SOURCE: Toshiba Studio 200 CP
Use the manual paper feeder, and set the paper type labels
Posted on Jun 18, 2008
SOURCE: spits out multiple blank labels and reports a printing error
I just fixed my coworker's Dymo, which had the same problem. I hope this helps: if you've ever fed it labels in the wrong direction (upside down), you may have jammed it and left a piece of a label glued to one or more of the sensors that let the labelmaker know it's finished printing a label.
1. Disconnect your labelmaker
2. Disconnect/remove any unused labels and set them aside.
3. Remove the face plate (with the DYMO LabelWriter 400 logo)
4. Lift the gray plastic lip (labels go under this) and make sure there are no pieces of paper/labels in there.
Once I removed a piece of an old label and put the LabelWriter back together it started working well again.
Posted on Dec 18, 2008
Joed911
  • 4338 Answers
SOURCE: One label prints, then red light comes on. We
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
Red light error :
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
Here is a trouble shooting guide:
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Posted on Mar 24, 2009
Sakeninja1
  • 5 Answers
SOURCE: PRINT WILL NOT STAY ALIGNED ON EACH LABEL-RUNS ONTO NEXT LABEL
Check the tension on the Ribbon Take-up Spindle there is a nut on it that sometimes can loosen or tighten its self and will throw off the lables. Its a nut that has a of couple Hex nuts on the corner, screw the nut to about the 3rd thread from the top of the bolt facing you then tighten the hex nuts on the corners of the nut. Then try printing the labels make sure the media guide also is set to the lable size that is installed.
Posted on Mar 27, 2009
micromatikal
  • 2777 Answers
SOURCE: Dymo 400 was working fine, then I had to unjam
You probably didn't damage it, it sounds like you may have knocked loose the thermal printing portion (which is the most important part). There is no easy way for you to repair this but Dymo will usually do it for free under warranty. Their phone number is:
(203) 588-2500
Posted on Jun 25, 2009
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
After printing a label it advances too far wasting the next label
This is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Jan 03, 2014 | Seiko Instruments Smart Label 450 Thermal...
How do I print onto a DVD
there are some printers where paper are not rolled inside the printer. in these kind of printers u can print dvd labels. so u need to get dvd label printer.
Sep 13, 2011 | Epson Office Equipment & Supplies
Printer prints faint labels
Hi. Thanks for your question
Print fainting could be caused by number of reasons. First think to check is ink roll. Replacing with new one would get this out of the way. If it still faints next thing I would do is once you opened the cover try and clean the print head and any visible rollers underneath the labels. Print heads can be cleaned with any alcohol solution. Best would be some kind of electronics cleaning solution. next thing to check would be labels themselves. It happened to me that labels where simply not very well finished and ink would not stick to them. Try roll of labels from other box you may have. If this all failed and your printer still faints labels that it never used to it could be the worse. Your print head may need replacing although this is very unusual for them to fail in this way.
I hope this helped you. Please don't hesitate to come back and ask more questions if this is needed. I've worked with thermal printers for 7 years now and I am sure we can find some solution to your problem.
Thanks for using FixYa
Dec 08, 2010 | Zebra Z6M Plus Thermal Label Printer
LABELWRITER RUNS THROUGH TOO MANY BLANK LABELS
Merely reboot software and then roll unused labels back on machine. That works for me.
Jun 04, 2009 | Dymo LabelWriter Thermal Printer
Print alignment problem. Prints across 2 lables. not sensing the black line on back of label roll.
As it turns out, a good cleaning took care of the problem. I suspect the sensor bar was dirty so it could not detect the black line on the back of the labels for alignment.
Thanks anyway!
Mike Sunderland
Jun 02, 2009 | Paxar Monarch 9855 Barcode Label Printers...
Cannot set label length
Performing, Setting, and Troubleshooting Calibration Issues
This solution is useful for
  • Calibration: consistent positioning of the label and the print
Symptoms addressed by this solution include
  • Prints, then skips a label
  • Print is overlapping onto next label
  • Paper out error is occurring
  • Print position is drifting up and down on the labels
  • Labels stopping in random locations
Perform a manual calibration:
http://tinyurl.com/qyb9z3
Z4m + sensors
http://tinyurl.com/qeny9r
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Zebra Z4M+ Printer
How can I fix this problem?
My printer is only a few months old. I have used up all the label roll that came with the machine and have put in a new roll (99010) which is slightly slimmer than the original one. I have selected the correct roll number from the list but the machine will not recognise it. It stops printing before the wording is complete and stops past the perforations (1/4 way into the next label). HELP!
Aug 05, 2008 | Dymo LabelWriter 400 Thermal Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Printing Round Labels
the issue sounds inpart to be related the set lable length, the printer thinks that the data will not fit on the label and gives the error. also note that the gap sensor is not in the center so the printer will not and can not autodetect the media correctly. you need to tweak the label setup. you could trick the printer by centering the labels over the gap sensor or if you do a autocalibating use the lable size it give you which would be much smaller then 17mm
Nov 12, 2007 | Zebra TLP 3842 Thermal Label Printer
Toshiba B-SV4D Label Printer Logo
112 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
