Question about HP Officejet Pro K5400 All-In-One InkJet Printer
My hp officejet pro k5400 cartridge cover keeps opening. The cartridges keep pushing out making the cover come open. Then the yellow and black lights keep flashing. I have replaced the cartridges and when I check the ink levels I get different readings. Either empty or half full. What is causing this. I can't not print and I have only had this printer a little over a year.
  • 3,600 Answers
It sounds like the locking mechinism is not latiching down tight go to www.hp.com and imput your printer number and you can get help withthis problem from them and if you register it it may be a free fix.
Posted on Nov 13, 2009
How do I replace the yellow ink cartridge?
Open up the Panel It has the writing HP office jet pro Etc. on it, then the cartridge/head will move toward you, push in on the yellow cartridge until it clicks and release it will disengage and you can remove old cartridge.
Installation is exactly like removal insert new cartridge until it clicks release and it will engage.
Close panel and the cartridge/head will move back to previous position
Jun 02, 2015 | HP Officejet Pro 8600
Black ink not printing properly on HP Officejet Pro K5400. It's a new cartridge, have tried another cartridge too but same problem.
The print head may be blocked.
Run the cleaning cycle a few times on the machine.
This can be done through the software drivers loaded on your computer.
If this does not help, you will need to replace the black print head.
Feb 14, 2011 | HP Officejet Pro K5400 All-In-One InkJet...
OfficeJet Pro K5400...ink cartridge
Er, NO.
The answer to the above question is clearly misleading.
If you consult the documentation for your HP K5400, which can also be found online, you will find that the printer cartridge lights also blink when the print heads require replacing.
If you have replaced the cartridge and the light still flashes, this is the most common solution. Replace the print heads.
Unfortunately because the printer is badly designed, there is no way of indicating this, and you will have troubles if you attempt to get the HP Toolbox or any other diagnostic tools working.
Feb 12, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
Prints only from color cartridges, black ink not working
The problem is in the print head.It's clogged or damaged.You need to replace it.It's part number is C9381A - HP #88 Printhead - Black and Yellow
Nov 01, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
HP K5400 will not print black
Check the black/yellow print head.If necessary replace it.It's part number is C9381A, #88
Oct 13, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
My KY yellow light is blinking. What should I do?
The k5400 is not recognizing that the ink cartridge is installed. Clean the contacts on the back of the ink cartridge and also the contacts in the K5400 printer. I always use 91% isopropyl alcohol, Hp says to use distilled water. Do let the contacts completely dry before reinstalling.
Feb 24, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
HP Officejet Pro K5400 All-In-One InkJet Printer Logo
259 people viewed this question
Seeker5211
Seeker5211
