Question about Yamaha RX-V1600 Receiver
RX-V1600 2 clicks but won't switch on
My RX-V1600 won't switch on. It just makes a couple of clicks but won't power up. It's been a perfect machine for 3 years without any problems. I've tried changing the fuse - this did in fact work a couple of times, but I'm convinced it's not the fuse! Simply removing the plug and re plugging in also worked too. However now it won't do anything but click when I press the power button.
  • fixya612 Nov 23, 2009
    Still no joy! I thought it could be a crossover with the speaker cables, so removed them ALL but without success. The shop recommended to remove all then try to switch on to see where the problem was. Still nothing, so it's gone in to be repaired. Let's hope it's not too expensive! Richer Sounds £40 to look at it and see what the problem is, then they quote you if it's more than £40.
I have the same problem, any resolution on this one yet?
Posted on Nov 22, 2009
Check your wiring for shorts. if there are none.
Then get the amp to a Qualified Yamaha Tech for repair / test / burn in and possible firmware update.
Posted on Mar 27, 2011
My RX-V2095 Yamaha receiver won't power up.
Wont power up, or stuck in "protect mode"? Unplug the unit & let it sit for a couple hours, then plug back in & listen for a "click" a turn (power supply relay energizing.) If no lights & no click, the first place to check is the mains fuse. If the unit is under warranty - take to an authorized facility & they will take care of it for you.
Oct 20, 2014 | Yamaha Rx-v2095 7ch Flagship Home Theater...
Yamaha RX-797 Amp not working
You have too much power being ran to the amp and it's overheating.
Lower your wattage.
Aug 18, 2012 | Yamaha RX-797 Receiver
Epson SX100 Scanner makes a loud clicking noise!
On the back of the Epson Perfection 1660 Photo there is a lever that shows a lock and a unlock by where you plug in the wire to the computer. It must be in the unlocked position otherwise it will make that loud clicking noise and not work. Hope this helps.
Apr 07, 2010 | Epson Office Equipment & Supplies
My HP media center desk top will not turn on. I have checked power and switched main plug. My son recently cleaned out the dust and showed me where to plug more power to speed the machine up. Which I...
make sure that this machine does not have switch on the pwr supply on back of pc.some times it is hard to see it. make sure there is pwr to the outlet and try different outlet. do you see any lights on back or front of pc. if not means no pwr is coming to pwr supply.
Dec 12, 2009 | Computers & Internet
My Yamaha RX-V470 Kicks off after a couple of SEC.
Two possible problems , bad memory back up cap or weak voltage regulator.
Jul 10, 2009 | Yamaha RX-V995 Receiver
Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Jan 02, 2009 | Yamaha RX-V995 Receiver
Yamaha RX-V1600 Receiver Logo
1,023 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
