Question about Dell 5110cn Laser Printer
When you try to print from a networked computer the display goes from saying ready to print to load Tray 1 A4. The tray is full of paper
When you loaded the paper in the tray, did you tell it that the paper was A4 - it may be that on the printer or in the queue definition on the computer that the paper size for that tray is set to something else (eg letter) and the print you are sending is A4 so it is looking for paper but only thinks it has other sizes available.
Posted on Nov 18, 2009
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Getting message to load tray 1 A4. load with
This problem is commonly found across printers, and is not specific to your printer model.
This problem occurs if:
  • You select the Hold mismatched documents option on the Advanced tab of the Properties windows of the printer.
  • The printer driver user interface (UI) plug-in uses the full UI replacement functionality. This means that printer driver replaces the default Windows printer dialog interface, so Windows fails to find certain registry keys to determine the paper type.
Microsoft has a hotfix for this issue for Vista and Windows Server 2008:
http://support.microsoft.com/kb/971319
If you are seeing this issue on XP, you can do the following:
1. Go to Printers and Faxes from the Start Menu (or type the following command in the Start->Run window: control printers).
2. Right click on the affected printer's icon, and click on Properties.
3. Click on the Advanced tab.
4. Uncheck the option Hold mismatched documents.
5. Some printers have the default paper type as Letter, so please change the printer properties to use A4 as the default
5. Click OK to save the settings change.
6. Wait for 15 seconds, and try to restart your printer job if needed. Usually, Windows will automatically restart the job, once the paper mismatch setting is resolved.
7. Ensure that you make the above printer property settings change on every computer where your printer is installed.
Happy printing!
Jan 21, 2010 | Dell 5110cn Laser Printer
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
When asking to print keeps saying load MP feeder cardstock A4 although computer set up to print from tray 1?
depends on the printer, normal home use printer have only 1 tray.
office printer usually have multiple trys. and usually the default for that is tray 2. tray 1 is manual feed.
May 14, 2009 | Office Equipment & Supplies
There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Apr 08, 2009 | Konica Minolta DiALTA Di200 Copier
Somebody has messed with the settings and now whenever we print we have to press "Select" for each page
The tray 1 is same as manual tray, it opens in front of you.
normally (in windows) you need to configure printer driver from printers => properties => printing preferences.
Oct 14, 2008 | Lexmark T632 Laser Printer
Won't print to right tray
I had this problem and solved it like this:
  1. Right click on printer driver in printers and faxes.
  2. Select printing preferences
  3. Choose paper quality tab
  4. Set paper size (A4 in my case)
  5. Set paper source to printer-auto-select. This is different from the default "Automatically select"
As long as tray 1 is empty, tray 2 should now kick in. Setting the paper source as tray 2 didn't work at all.
You seem to have to set this on each client computer though - even if you are sharing the printer over a network (4200n).
Sep 23, 2008 | HP LaserJet 4200 Printer
Only wants to print out of tray 1
paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
Nov 30, 2007 | HP LaserJet 4350 Printer
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
Dell 5110cn Laser Printer Logo
261 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
