Question about Dell Axim X3i (400 MHz) Pocket PC
Hiii i just bought this Medion pocket Pc, and it says align screen and nothing happens. what do i do from here...have tried to take out the battery and stuff..nothing works. plz help
  • 35 Answers
SOURCE: Can't charge My dell Pocket Pc axim v5!
Make sure that battery is properly in place. Somertimes it will charge in the cradle but not actually charge if the battery is loose or not seated properly.
Time for a new battery
Posted on Aug 17, 2009
0 characters
1 Points
I have an imate pda2k pocket pc and is working good. Out of curiosity i tried hard reset and it ends to align screen. Everytime i made a hard reset the screen show " tap the screen to setup your pocket pc"...
tap and hold on align target until it moves to next corner or next step, if you are using windows 6 or 6.5 you should be very much accurate on taping and holding to align the screen.
Nov 01, 2009 | i-mate PDA2k Pocket PC
I have a i-mate jama Pocket PC, yesterday it turn off due to low battery. Today I recharge it but it hang on align screen message..... I have tried several times but all in vain...
you should reset your phone.reset code is 1234.after that "align screen" shows
tap the screen at target for few moment untill align screen does not takes several attemp.after align screen disappear time & date setting option appear.set it.after this window will takes few minutes.after this phone will be started.
Sep 26, 2009 | i-mate JAM Pocket PC
I have a problem with aligning the screen
on my pocket(qtek9090) i have anather problem,i have lost thet function.And after the full restart, c'not sign in because aligning its not work...????
Aug 27, 2009 | i-mate PDA2k Pocket PC
Screen allignment hp ipaq hx2410 pocket pc
Try Realigning the Touch Screen
1. Tap Start > Settings > System tab > Screen.
2. Tap Align Screen and follow the instructions.
Mar 18, 2009 | HP iPAQ hx2410 Pocket PC
I can't make my IPAQ pass the align screen
Replaced LCD touch screen in Australia.  Cost $95.00 AUS Thanks for Fixya help you where really great.
Feb 12, 2009 | Compaq iPAQ H3955 Pocket PC
Imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Oct 06, 2008 | i-mate PDA2k Pocket PC
Stuck On Align Screen
This happened to me also. Drain the battery completeley and then do it again. You may have to do it a couple times but it will finally take.
Mar 20, 2008 | T-Mobile MDA
Hard reset does not wok in my ipaq H3955
The touchscreen may be broken, try hardreset again if it doesn't help contact your dealer or HP for possible repairs.
Sep 14, 2006 | Compaq iPAQ H3955 Pocket PC
Align screen
I have the same message if the unit is without power supply for a long time but it should not happen every time you switch the PDA on. Maybe is the battery defective.
Sep 11, 2005 | Toshiba e400 Pocket PC
Dell Axim X3i (400 MHz) Pocket PC Logo
24 people viewed this question
Top Dell PDAs Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Dell PDA Expert? Answer questions, earn points and help others
