Question about Canon DR-2050C Path-Through Scanner
The pages of docs are jamming near exit of paper and/or pulling other pages also. The roller looks worn. How easy is it to replace the rollers ourselves?
    Novelist:
  • 175 Answers
It is really easy to replace the roller. You open up the scanner using the pinch tab on the front and lift the lever that holds the rollers and pull them out to replace them with new ones. New rollers can be purchased on ebay.
Posted on Mar 02, 2011
Hp laserjet 4520n: Attention indicator is blinking, printer is not printing showing paper jam in tray 2. No jam actually !!!
Look at the feed rollers.
If you pull the paper cassette out and look into the now exposed area, you will see two rollers in the machine, just above where the roller in the front of the paper cassette was positioned.
If these rollers are worn, they will not grab the paper and pull it out of the paper cassette. This will cause the machine to think that there is a paper jam, even though no paper is found in the machine because the machine is looking for the paper via a paper path sensor in the front of the machine, just a few inches up from the paper cassette.
Look closely at these rollers... they should have a "rough" surface. If any of them are smooth, you will have to replace them.
There are two blue hub rollers and one white roller.
Part #'s:
Blue: RM1-0037-000CN (Qty.2)
White: RM1-0036-000CN (Qty.1)
Oct 25, 2010 | Office Equipment & Supplies
Hi, I've had this Samsung color laserjet (CLP-510) for a while now - found no reason to upgrade cause it's a great work horse. Now however from job to job it grabs an extra sheet of paper or two, and then...
It seems more likily that your pickup roller and separation pad has already worn out.
You may want to try pull out your paper tray and remove the pickup roller. Adjust the pickup roller and the paper tray separation pad may help.
next you may want to test with a single sheets of paper to see if the paper jam at the back of the printer near exit. If it does, you will need to replace your fuser too.
you can check the supplier info by going to menu -> system setup -> report -> supplier infor -> print -> yes.
Information below for item that is wear and tear.
1. Fuser - 25K +/-
2. Transfer roller 20K +/-
3. Transfer Belt 25K +/-
4. Pickup roller 20K +/-
5. Image Drum 25K +/-
hope this help :)
SamsuTech
Feb 20, 2010 | Samsung CLP-510 Laser Printer
242.13 paper jam error We cannot find any paper jammed in the paper
hello,
The paper jam error 242.13 can be caused by an actual paper jam in the printer but since you did not find any paper the next thing would be pickup rollers. The pickup rollers can become worn and if they don't grap the paper right it will not more from the tray. There is a sensor that tells the printer that the paper exiting the paper tray and to start the printing. If this sensor does not detect paper when it should be there it gives a "paper jam" error thinking the paper is jammed. Look at the top page of paper for 1 or 2 light gray marks. If you see them then the rollers are the problem. You can see the rollers if you turn the printer on its side and remove the paper tray. To test the pickup rollers you can take off the rubber rollers( they look like white rubber band) from the wheel and turn them inside out, this will work as a temp fix untill you can get them replaced. If you need them replaced we can provide them or you can call a local repair show. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 18, 2009 | Lexmark T644 Laser Printer
Paper getting stuck in the rear of Brother 2820 fax machine...
Hi, There are many reasons for jams in the exit of machines and I will list the most common for you damp paper will curl as soon as it hits the fuser rollers... the fix - change paper the fuser rollers are worn (teflon coating is no longer able to deflect toner) and jams are occurring.... the fix - replace the fuser unit
Jun 09, 2009 | Brother IntelliFax-2820 Laser Fax
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Apr 07, 2009 | HP LaserJet 4 plus Printer
Printer jam upon exit
Check the paper output area ( around the output rollers) for a small piece of paper. You may need to disassemble the output paper assembly, and clean the rollers, or replace the paper output assembly.
In reality, what you have is one part of the printer trying to "push" the paper, while another part of the printer is trying to "pull", resulting in the wrinkle.. The problem may also be with a paper output sensor being stuck, which is why I suggest you check thoroughly for paper scraps in the output assembly.
Nov 14, 2008 | HP LaserJet 3030 All-In-One Printer
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
XEROX 5328
That is an exit Jam code in the fuser.
You may just have one of the fingers bent straight down blocking the paper.
There also may be a secondary code that is causing the E-4-0.
But that is where to start. Look under the exit web cover for a piece of paper crumpled in that area.
Once there you may have to remove the fiser web cover to remove that jam and straighten out the finger.
MAKE SURE IF YOU GO INTO THAT AREA TO UNPLUG THE MACHINE.
Dec 07, 2007 | Office Equipment & Supplies
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Canon DR-2050C Path-Through Scanner Logo
172 people viewed this question
old marine
old marine
