Question about Motorola Mobility RAZR V3i Cellular Phone
It display the network name and no service - Motorola Mobility RAZR V3i Cellular Phone
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
Internet crashes my htc Smart... Help?
The first time you use your device, the Connection Setup displays a notification message to inform you that it will automatically configure your device's data connections, such as 3G/GPRS/EDGE, WAP, and MMS.
  1. On the notification message, select Yes.
  2. If your SIM card supports multiple network operator profiles, the next message displays all network profile choices. Select the profile you want to use, then select OK. The Connection Setup configures your device's data connection settings.
  3. After the Connection Setup completes configuration, tap Restart. Tip: To choose the network operator manually, select Start > Settings > Connections tab > Connection Setup The GPRS/3G settings are preconfigured on your device when you applied for this service with your wireless network provider. If you need to add another GPRS/3G connection:
  4. Tap Start > Settings > Connections tab> Connections
  5. Under My ISP, tap Add a new modem connection
  6. On the Make New Connection screen, enter a name for the connection, select Cellular Line (GPRS, 3G) on the Select a modem list, then tap Next
  7. Enter the Access point name, then tap Next. You may obtain the access point name from your wireless service provider.
  8. When prompted, enter the user name and password. (Check with your wireless service provider if a user name and password are required to connect.)
  9. Tap Finish
Feb 09, 2012 | HTC Cell Phones
What is the ssid
SSID is an identification for your wireless network
Mar 08, 2011 | NetGear WGT624 Wireless Router
As always you can find answers to your questions at www.xerox.com/support
Solutions for : Enter up to 64 Characters in the Shared Name Field Message is Displayed When Setting up a Network Scanning Template Using CentreWare Internet Services (CWIS)Related Fault Codes: 016-782 Solutions ranked by relevance Solution : Modify the User Login Name to a User that Only Exists on the SMB Server Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
  1. Open an Internet web browser.
  2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
  3. Click on the [Services] tab.
  4. Click on the [Job Templates] link.
  5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
  6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
  7. Select the required File Repository from the File Repository Setup pull-down menu.
  8. Enter a username that only exists on the SMB server in the Login Name field.
  9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
  10. Click on the [Back] button. The File Repository Setup window will be displayed.
  11. Click on the [Template] radio button. The Device Template window will be displayed.
  12. Click on the [Create New] button, and then setup the template again.
  13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
Hope it helps!
Jan 10, 2011 | Xerox WorkCentre M128 Copier
I am using internet through nokia C3 phone. After starting the net for 1-2 monites the net works fine but afterwards the eroor comes line ERR105 net Err name not resolved server not found. Am i alos...
Contact a network service provider. The device is wireless capable takes time to search for available signals displaying an error without successful attempts. The device appears to have a prior network provider because has firefox interface which is a display browser to a network.
contact a network provider to get connection signals.
Dec 21, 2010 | Computers & Internet
CAN MY DELL PP29L CONNECT TO ANY WIRELESS SERVICE
yes it can.
go to control panel >> double click on network connections >> right click on wireless network connection and click view available wireless network. then click on your network name and connect wirelessly.
Feb 26, 2010 | Dell Inspiron 1521 Laptop
Couldn't register service provider. Display shows ''LTD. SERVICE''
Its purely network problem. Dont try again and again with the same solutions. Switch off the mobile for some time, remove battery, and sim card, and put them again after some time and switch it on. In samsung, while switching on, it will show the service providers name in the start up screen. if it shows, then it should work. If it doesnt work, some problem with the sim card. try to replace it. or otherwise general operation in selecting the network shud help.
Aug 10, 2009 | Samsung Cell Phones
How do you setup remote
  • Automatically configure an Ethernet connection
  • Click Start and then click Network. The Network window displays.
  • Click Network and Sharing Center.
  • Verify that the network is connected to the computer. The network is connected to the computer if a red X does not display on the screen.
Figure 1: The computer is connected to the network
Figure 2: The computer is not connected to the network
Connect the printer to the network with an Ethernet connection.
  • Click Add a Printer.
  • Select the Add a network, wireless, or Bluetooth printer check box.
  • In the list that displays, select the desired printer and then click Next.
  • In the Printer Name text box, type a name for the printer.
  • If desired, click Print a Test Page to print a test page.
  • Click Finish.
May 28, 2008 | HP DeskJet F380 All-In-One Printer
Cell display of area/location and Service provider name ( SP5m)
Generally, SIM cards carry the names of network providers. At times, a device may have the list of network provider "Nice Names" which correspond to the network provider's actual network display. Example: 310-490 -> Suncom Wireless If Suncom Wireless is not in the list defined by the SIM card or device, "310-490" will be displayed.
Jun 21, 2007 | i-mate SP5m Smartphone
Motorola Mobility RAZR V3i Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
