Question about Maytag Neptune MAH5500B Front Load Washer
My neptune has progressively gotten more violent during spin clcles. The loadis not unballanced, so I was wondering what could cause this? Did a mount come loose?
  • 3,600 Answers
Try adjusting the feet they screw in make sure all four of the feet are touching then give it a 1/4 turn to get it tight. then try it, if it still bounces around you have a problem interanly.
Posted on Nov 13, 2009
    Genius:
  • Maytag Master
  • 1,474 Answers
Could be broken spring ' top of drum or suspension leg @ bottom. maks sure level on floor ok..
Washing machine shakes violently during spin
Hi
If your washing machine shakes violently or if there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Also check this link bellow:-
http://www.wikihow.com/Fix-a-Shaking-Washing-Machine
May 03, 2011 | KitchenAid Washing Machines
The washer shakes violently then the off balance sensor trips when a load is in the washer.
I had this washer at one point in time. was not very happy with it, even though i sold it to alot of my customers. usually if the machine is shaking violently it means one of a couple things. first make sure your washer is properly leveled. if it is make sure you washing the same types of clothes in the load, no mixed loads of towels with shirts. if your problem is not that then you possibly have a bad clutch. which will cause the tumbling wheels to spin during your spin cycle as well, its a costly fix so i would consider a new front loading maytag/whirpool if that is your problem. remember this machine was designed by maytag, since then they were purchased by whirlpool and everything is on a whirlpool platform now. if you do purchase a new washer and have the matching dryer to your neptune TL, it would recommended to replace the dryer as well, considering the capacity of these machines are smaller then most of the new high efficiency machines on the market today.
Feb 19, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Wahser jumps around during spin cycle
rking9847
If your machine model is an FAV6800A or FAV9800A the issue could be a Clutch malfunction.
Does the Spin cycle error out with unbalance errors such as dC or uC if your machine is one of the above machine models?
If so see this post Clutch Fix for a step by step to Clutch maintenance or replacement if necessary.
Post back if you have additional concerns with your FAV6800A or FAV9800A.
Rich
May 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune MAH5500 Neptune has progressively gotten louder on spin. Very loud noise sound like bearing going. Continues to get worse. Can it be fixed or too expensive to justify?
Hi.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, Check if the drum has excessive play.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
To get a quote on repair call Maytag at the number listed on the owner manual, the machine may still be worth repairing.
You can find parts and diagrams for most models here.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washing machine spins violently and the ground
Possibly you still have the transport screws in. this causes havoc when load is in. or very unballanced load or possibly spring come loose . assuming you have a front loader. Definately one of those.
Sep 15, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
I had this problem as well. I called dealer and Maytag. They made an appointment and stood me up several times.
I finally went to place that sells refrigeration equipment and bought an anti-vibration pad. It's a 12" square waffle pad used under large equipment to prevent them from vibrating loose on connected piping. I cut it into 4 pieces and put one under each corner of the dryer. Problem solved, in fact it worked so well that I stacked dryer over washer, placed pads between units and have not had a problem since. I also gained a lot of space in my laundry room as well.
Mar 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Matatg Washer Model PAV2200AWW
Sounds like you should be getting a UC display that would indicate an out-of-balance condition. If it's not happening then you're either not getting a signal from the tub position sensor located near the front of the tub because it broke off or is faulty.You should check this first.
Mar 09, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH6500
Sounds like some sort of broken support or spirng underneath. Flip it over and look. Expect a little water to run out though.
Feb 28, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
81 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
