Question about Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White
Spa 2 go pump stopped. Need to replace the pump? How much to do this? Do you replace the entire unit, or do I need to open it and repair just the pump?
  • 279 Answers
Is the motor running? If it is there could be a coupler broken. If the motor is not running, it could be the problem. If the motor is not running, is there power to it? If not, it may be a broken switch that controls the motor. If the motor has power but not running, then probably the motor, its starting system or bearings. Bearings? Yes, they may be frozen and or dry. Dont spend a lot of money until you have the problem located. Good luck...Lee
Posted on Nov 13, 2009
  • beth1264 Mar 31, 2011
    Please call 888-997-6366 in order to determine if a replacement/repair is even necessary
OK, well the pump is running, it appears the heating eliment is fading or most likely gone.  There is a faint feeling of heat if you put your finger over the water coming in for 15 secs. then it's gone, not enough to heat up the Spa2go tub.  So, my question is where do I get a exterior Spa2go replacement filter pump?
Posted on Mar 12, 2010
  • costiles Feb 06, 2011
    My spa2go heater went out as well. I am looking for a replacement pump.
    If you are certain that you need a replacement there are 3 options available. You could send it in for repair by simply calling 888-997-6366. Or you can purchase a remanufactured power pack through the exchange program by calling 888-997-6366. Or finally you could purchase a brand new power pack by either calling 888-997-6366 or on the website at http://www.oceantis.biz/Replacements.htm...
    Problem Solver:
  • 6 Answers
If you are in need of trouble shooting assistance you can call 888-997-6366 in order to further trouble shoot your water circulation issue. If the water pump itself needs to be replaced you do not necessarily need to replace the entire power pack. There is a repair facility that works on these units, simply call the toll free number above and they can further assist you.
Posted on Mar 31, 2011
Need 2 complete replacements for a FLo Master spa pump 06630397-2 -do you carry and how much?
best is to see if they can be repaired, you need a experienced pump repair shop with free testing, these are hard pumps to work on. or keep a eye out on craiggslist.
Sep 29, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Need to replace old pump.
easy both of them are junk. get a (sta-rite max e click on it) a 1.5 hp should do just fine. the 2hp is to run your spa and not economical to do unless you you have two pumps one for the pool and one for the spa.. if you have a 2 story house with solar you will need a 2hp
used pumps can be tricky so search for your local pool pump repair guy and see if he could build you one, this will save you money and be handy if you need repairs in the future ! ask him how to take care of your pump !
jay the pool pump repair guy longwood Florida
Sep 05, 2012 | Pentair 2 hp Challenger Pump
Stopped sucking
YOU WILL NEED TO CHECK THE IMPELLER AND I WOULD REPLACE THE SHAFT SEAL !. REMEMBER TO PRIME THE PUMP AFTER ANY REPAIR.. THERE IS A GUY ON EBAY THAT SELLS SHAFT SEALS FOR HAYWARD PUMPS WITH A how 2
Jun 06, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
My pool pipe broke open and the water pumped out - about 2 feets worth and the entire hot tub before we shut the system down. I just had the pipes fixed, turned it back on and now the motor is whining. Is...
nope sorry these are sealed bearings and wd will make things worse ! there is nothing you can or should spray in or around the motor ! the motor needs bearings and a new shaft seal, cost is around 75.00. if you fail to do the repair in a timely manor the motor can fail and will be junksearch for your local pool pump repair guy in your area .. here is how to remove your pump . hope i was of help j
May 26, 2011 | Hayward 2HP Pool Pump Motor A O Smith...
Motor runs but will not pump
Remove the unit and open up the pump end and inspect the impeller for blockage or perhaps it is broken; clear or replace as needed. You should also replace the pump seal at the same time. If these seem beyond your ability a local electric motor repair shop should be able to do this for you for less than $60.
John
Oct 10, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Need to buy replacement heater for comfort line portable spa... but have no idea where I can find one. Please help. Motor, heater and pump overheated, and just never started up again, even after it was...
http://www.oceantis.biz/Replacements.html
The above link is for the people who have bought out comfort lines product lines.
There is a link there for the replacement spa pack..
The original manufacturer is out of business.
Pack is about $450 US
Sep 14, 2010 | Comfort Line Spa 2 Go Portable Spa with...
My Nitro Wall climber only cleans a small area back and forth for the entire 3 hour cycle. It litterally rocks back and forth in 1-2 second motion spurts. The drive wheel in the back seems to be working,...
The pump motor is responsible for the programming of the unit and it is failing. You will need a new pump motor installed to correct the issue. For information about sending the unit in for repair you can try our site at www.arrowpools.net or the manufacturer at www.smartpool.com.
John
Aug 19, 2010 | Smartpool Nitro Robotic Cleaner and Caddy
Jandt filter leak
it depends, if it's leaking due to a crack on a structural part of the filter such as the tank itself, then yes, the entire tank will need replaced.
Feb 18, 2010 | Jandy PUMP SHAFT SEAL - FITS PUMPS
How do we get our pool pump back to filtering the pool? It was working for the first day! Now it not doing anything and we have taken the hoses off and did the air in the pipes check, and still not working...
Make sure the selector on the filter is set to "filter" also check that there isn't any obstruction found in the intake pipe coming from the pool to the pump. Make sure the pre-filter basket just before the pump is clean and free from obstruction. Check all valving is open on the intake pipes and discharge pipes exiting the filter.
Jul 05, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White  Logo
3,177 people viewed this question
Top Comfort Line Pool & Spa Experts
Jay Finke
Jay Finke
john h
Bill Boyd
Are you a Comfort Line Pool and Spa Expert? Answer questions, earn points and help others
