Question about LG RUMOR Cellular Phone
Can I get rid of the location icon?
I have a rumor (the first one) and I turned the location off but now the icon is there with a red slash going through it. Am i able to get rid of it?
I have my tascam bb-1000cd and a wireless mic into record and there is a speaker icon with a slash across it
A speaker icon with a slash across it = your speaker is on MUTE. Try to turn the sound volume up or if you have a MUTE button on the device, press on it to UNMUTE the speaker.
Nov 18, 2014 | Tascam BB-1000CD Portable CD/SD Recorder
Unable to turn on the sound on my Asus tablet T300. What do I do ?
The sound icon with a slash means the mute is turned on. Tap on the icon to see is there is sound otherwise you have to go into settings and manually turn on the sound.
Jun 12, 2012 | Tablets & eReaders
Can still operate phone but it constanly blinks..
The LG Rumor cell phone is a practical and easy-to-use device that offers two modes of typing through a regular number dial pad and a full QWERTY keyboard. Like any cell phone, the LG Rumor can have errors that prevent it from working properly. Troubleshoot common issues by updating software or checking the power cycles.
Instructions Things You'll Need
  • Internet connection on LG Rumor cell phone
  1. Check and update device software
    • 1 Locate and click the home screen icon.
    • 2 Locate and click "Menu," "Tools" and "Update Phone."
    • 3 Click on "Update Firmware."
    Update device data profile
    • 1 Click the home screen icon.
    • 2 Locate and click "Menu," "Settings" and "Data."
    • 3 Click "Update Profile."
    Power cycle cell phone
    • 1 Turn off the cell phone.
    • 2 Locate and remove the battery.
    • 3 Install the battery after one minute.
    • 4 Turn on the cell phone.
Jun 12, 2011 | LG RUMOR Cellular Phone
ZR80 Mini DV Digital Camcorder: I have a blinking red icon with a slash through it...
Sounds like the memory battery indicator. Does it look like a button battery with a slash? If it is, you probably cannot set the date and time also. It takes a CR 1616 button battery and goes in the window behind the main battery.
May 16, 2010 | Canon ZR80 Mini DV Digital Camcorder
D drive which is my dvd/cd drive has a red circle and a slash on it. it says access denied. how do i fix?
If confronted with this trouble I believe id go to the device manager and delete the drive then let windows reinstall it.
You may want to see what the comments are on the drive tab. There may be an upgraded driver available for hour device.
Is this computer yours and have you inadvertently restricted your access in the user profile?
Oct 13, 2009 | Acer Aspire 5500 5570-2609 Laptop
Lg Dare phone
Leslie,
I had purchased and am currently using the LG dare. The issue that I had with the icons apprearing on my main screen was that I was accidentally holding down and dragging the icons from my shortcut menu to the main screen. The easiest way to get rid of the icons from the main screen is to hold down the icon and drag it to the little arrow for the shortcut menu, and it should dissapear.( I just did it on mine so it should wok for you).
If that doesn't work, open you shortcuts menu, hit the set button and remove the icon from the shorcut menu (this should remove it from the main screen as well.)
good luck!
Nov 16, 2008 | LG RUMOR Cellular Phone
K800i un-deletable items
take the phone and have the firmware reflash
May 13, 2008 | Sony Ericsson K800i Cellular Phone
"DV IF" Flashing
To get rid of the DV IF flashing go to >menu>systems>DV control ...OFF. (page 63 in the instruction manual)
Mar 06, 2008 | Canon XL1S Mini DV Digital Camcorder
LG Chocolate Pink K800
It sounds a bit like an infra red icon but I don't really know. Go to connectivity and infra red and turn infra red off. Hope this helps
Jul 30, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG RUMOR Cellular Phone Logo
35 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
