Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
The brushes will not turn but the shampooer will come on
I have a Hoover SteamVac carpet and floor cleaner,the brushes will not turn,the hand held one for steps moves but the big one for the floor want.I think it may be a belt but I don't know where to look.
1) check the filter by the spin indicator (the plastic cover snaps off). Clean if necessary. See if this solves your problem.
2) take out the spin brush assembly (pull out, there may be tabs you need to push to get it all the way out. Clean out dirt and hair. This may be all you need to do, if not take step 3
3) turn on the machine with the brush assembly out. Do you see where the square shaft the drives the brushes goes in? If the socket does not spin, you probably have a seized up turbine assembly.
4) remove the top that covers the motor/turbine (you probably have to take out some screws) The turbine assembly is towards the front. Remove this (again, a couple of screws) and turn it over--there will be some gears. If you can get these gears turning smoothly together you should get the turbine working again. I used a pair of pliers to turn the metal shaft.
Put everything back together and try it out!
Posted on Jan 23, 2012
  • philip graceffa
    philip graceffa Oct 12, 2014
    also clean and lube this small bearing inside this turbine.
I have a Hoover Steam Vac Deluxe, in addition to the switch, there is an Indicator Screen on the bottom of the unit. if this is clogged, the brushes will not work correctly.
That has solved my problem in the past, but now with a clean screen and the switch in the proper location, my brushes still will not spin. anyone have another solution?
Posted on Nov 26, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
I have a Hoover SteamVac, it's brushes are driven from a gear case. There is no belt. Mine has a selector on the top of the unit near the brushes, you can select the brush speed (high, low, off). I shut the brushes off once and my wife was the next to use the machine and did not realize the brushes were off until half way through the house. Post your model number and it will help determine if yours has this selector.
Posted on Nov 15, 2009
    Genius:
  • Hoover Master
  • 1,466 Answers
Cover should come off faceplate to show belt// if brush roll spins freely then belt has gone... if not belt okay
Posted on Nov 13, 2009
Hoover carpet cleaner dual 5
Try this site for more information on this problem
It may just need a good clean out.
http://hoover.com/support/manuals/?q=SteamVac
Feb 05, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How do I take the top off my hoover spinvac shampooer
1) test the motor outside from the machine, carefully and do not touch any side live wire.
2( see the diagram simple for help and test the motor, otherwise you must go to the repair shop motor.
God bless you
Jun 18, 2012 | Hoover SteamVac Carpet/Upholstery Deep...
On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
Follow these steps if the Brushes Fail to Spin
•If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
My brushes on my hoover steamvac all terrain carpet and hard floor cleaner will not spin what do i do
I am not sure if you have the F7222 or F7452 all terran. There is a plastic piece on the back of the block brush (spin scrubbers) these wear out or break. You may need to replace the block brush. You can find the parts below follow the link. Please don't forget to give positive feedback.
Hoover F7XXX Link
http://www.usavacuum.com/Hoover-Steamvac-s/107.htm
Jan 29, 2010 | Hoover STEAMVAC VACUUM Vacuum
The brush won't spin on my hoover shampooer
This machine has an airdriven turbine that drives the brushes. The turbine needs to be replace because it is spinning on a steel bushing which gets rusty from all the water going through it.
Nov 26, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
MY WIFE BOUGHT THIS FOR ME FOR FATHERS DAY GIFT ABOUT ALMOST 2 YEARS NOW OR SO,BUT I HAVE THIS PROBLEM THAT THE BRUSH DOS'NT SPIN ANYMORE EVERYTIME I PUT THE SWITCH ON FOR BRUSH ON,THE HOSES BRUSH SPIN IS...
This unit uses a turbine assy to turn the brushes. The brushes could have something jamming them. Remove the brush unit, it is held on 2 spring hooks 1 on each side. The brush unit is driven thru a 1/4" square post, only one brush is driven and it drives the next then it drives the next etc. If something is jammed in these gears it will stop the entire brush assy. The turbine assy could be bad, but I would check the brush assy first.
Nov 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The brushes wont spin on my Hoover rug shampooer Model # f7220-950.
try cleaning brush...
if sam problem need replaced turbine part no: 43191009 Turbine & Gear Assem
Nov 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Deluxe
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=624426
Posted by providence51 on May 26, 2008
My cleaner is not dispensing the shampoo solution. Still sucks up the dirty water that I manually applied with a scrub brush. I use this on my tiled screen porch floor and it has worked great many times.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There is a release value in the bottom the holding tank that may be bad and not opening or the trigger assm in the handle may be broken and not connecting to release the water to scrub and clean the carpets. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
354 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
