Question about Nokia N95 Cellular Phone
My N95 keeps locking and turning it self off - Nokia N95 Cellular Phone
My n95 is locked & I have forgotten the lock code
try using the following method ..this will format whole of the phone memory
1.Turn of mobile initially
2.Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
3. While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Jul 02, 2010 | Nokia N95 Cellular Phone
Ive forgot my lock code for my n95 8gb, how can i reset it? also im from the uk. thanks
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Jun 24, 2010 | Nokia N95 Cellular Phone
THERES A LOCK ON MY MOBILE N95.HOW CAN I REMOVE ?I FORGOT THE PASSWORD.
Jun 11, 2010 | Nokia N95 Cellular Phone
Noka N95 8gb keeps turning off and not restarting
ba83ee5.jpghello,you do not try master reset *#7780# or *#7370#
please remove your mm c card and switch off your mobile and 5 minute after you try without you mm c card; then no solution so, you are watch nokia care
Apr 20, 2009 | Nokia N95 Cellular Phone
My nokia n95
HI I THINK your phone is affected by virus update your firmware..and check it thank you.......
Mar 08, 2009 | Nokia N95 Cellular Phone
My nokia n95 keeps turning itself off
my nokia n95 keeps turning of . every time i try to turn it on it turns on and keep restarting till the battery dies.. any solutin for it please.
Jul 05, 2008 | Cell Phones
Message and call log cannot open
Turn off the mobile device. Then press and hold "3", the "Green button" and "*" - Turn on and keep holding the keys until the mobile phone restarts and prompts you to enter details. Its going to ask you to put a code. If you already have a lock code on your phone, use that, and if you don't have a lock code on it, then try 12345.
Jun 27, 2008 | Nokia N95 Cellular Phone
I forgot my security code n95
after months without my n95 and hours of scannin the internet i have found the solution to the lock code!!!! if u hav totaly 4goten the code u will need to flash the fone but...... if like me you are 100% sure the code u keep entering is correct then here is how to fix it!!! when changing your code u would have enterd a 6 digit code and re-enterd it to make sure it is correct yes? all went fine! wen entering it again it faild? thats where the problem lies. enter only the the 1st 5 digits of ur code and all should be fine!! if this fails turn off ur n95. press and hold the green key, the # key and the 3 key all at the same time as turning the fone on. keep them held untill the the lock code needs to b enterd. then repeat the 5 digits of ur code. unfortunatly u will loose contacts and msgs etc but it works! have fun!
Jun 19, 2008 | Nokia N95 Cellular Phone
N95 unlocking
When you have the unlocking codes for your N95
1. turn phone off
2.take the battery off and the sim card out.
3. putt battery back in
4. switch phone on
5. enter unlock code using non predictive text.
Nov 12, 2007 | Nokia N95 Cellular Phone
Phone keeps freezing
u need to do hard  reset of ur fone and pls take back up before that...or else there is problem with charging slots pins and turn on/off button,,,,,,,,
Sep 09, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
29 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
