Question about Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum
No vaccuming The brush is still turning so the electricity is still going through but it's not vacuuming. Push the button and nothing is happening. After only 10 minutes of "working". thanks!
    Genius:
  • Bissell Master
  • 1,466 Answers
Leave it to Cool may have tripped themal switch
Posted on Nov 13, 2009
Vacuum cleaner does not work
most upright vaccums have a reset button at lower rear area of the vaccum. operates similar to gfi plug reset, push button back in usually with small screwdriver. is your debris bag to full? power brush jammed with debris? hose plugged? this will cause motor to over heat and in turn kick out reset button. always unplug power cord before putting fingers in areas where moving parts are!!
Jan 01, 2012 | Bissell Vacuums
Lately, my vacuum will only turn on when the accessory hose is hooked up. If I have the carpet brush attachment in place, the power will not turn on. I noticed that there are 2 switches that need to be...
It is most likely the switch. To be certain, hold the lower switch button on the front in with a small screwdriver and push the switch. BE SURE to push the button in first, and then the switch. If the motor doesn't start, you need a new switch assembly.
Feb 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Turn on the power and nothing happened. I checked the power plug. It was ok. what caused the Vaccum didn't work? Thanks, Peter
Same, I have the same issue with this model. Brush motor is working but not the vaccum motor. Any ideas?
Jul 26, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Mar 24, 2010 | Miele S318 Bagged Canister Vacuum
My new vaccum wont pick up cat hair
i would return this vacuum while it is still under warranty.
Aug 22, 2009 | Vacuums
Twirly thing under the vacuum has stopped spinning
there is a belt that drives the beater brush. flip the unit over, you can remove the bottom cover by removing a couple of screws. to one side of the brush you will see a channel where the belt should be. go to you local walmart, sears or hardware store and in the vaccume section they will have belts, on each bag of belts will be a list of vaccumes that belt fits simply find yours. with the new belt simply lift the beater brush out at the belt channel side and install the belt around motor shaft and brush. then place brush back in place , be suer brush guides are in properly. this should do ya.
Aug 18, 2009 | Dirt Devil Featherlite Bagless Vacuum...
I have a Eureka Bravo! 7.0 vaccum cleaner, how do I change the belt
Turn the vac over so the brush is facing up.. There is a cover plate that surrounds the brush.. Take the screws out and remove the cover plate.. Pull up on the side of the brush that the belt is on.. Replace the belt.. The belt goes around the metal shaft and the brush.. Push the brush back in place.. It might be a bit tough going in because the belt causes some tension.. Put the cover plate and screws back in..
Good luck ! Please don’t forget to rate well ;o)
Aug 14, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
The vaccum turns on but the brushes dont spin, and i have hit the reset button on it already...
vacuum turns on and sucks but the brush does not spin and I have pushed the reset button
Mar 20, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Rotating bruch
take off the bottom cover where the roller brush is a few screws should be all it takes underneath cover should be roller and belt if belt is broke replace it lift up roller there is a slot for the belt to run in put other end should be the motor side put belt around pulley bar put it back the same way it came off.
hope this helps
Dec 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum Logo
83 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
