Question about Yamaha Dtxpress III Electronic Drum Set S-O System
Problem with kick pedal directly after another pad is hit.
I just got a used Yamaha DTX electronic drum kit from a buddy of mine. with the problem being the bass drum. you can kick the bass drum as much as you want and no problems. but if you hit any of the other pads and kick the bass drum directly afterwords, it don't register with the system so it's missing beats when I try to play. any ideas to the problem or a way to fix? thanks for your time...hope someone can help me
2 Suggested Answers
  • 7 Answers
SOURCE: Electronic snare drum pad picking up tom tom triger signal ?
your right old and new technologies are all the same basic concept, a Piezoelectric transducer converts mechanical energy into an electrical pulse. Adjust/increase the cross talk (x-talk) setting on the module for your specific channel. this settings job is to disregard really small signals (ie. vibrations from the stand, other drums etc...), you may have to play the pad a little bit harder but it should work fine.
Posted on Jun 17, 2009
Yamaha manuals
Providing it is plugged into the correct socket on the brain it is probably a broken cable. You could try using one of the other as a tempoary measure to check this if not then either the switching in the pedal has failed or a problem with the brain unit. Try cable & factory reset
Jul 11, 2014 | Yamaha DTX400K Electronic Drum Kit
Hi. I've got a problem with my hit hat controller with my Yamaha DTXPRESS III special. It is still opened, even if I strongly push on the pedal. But, when I half plug the jack in the hit hat controller it...
Sounds like the internal switch in your pedal.
Get an OHM meter, and check the continuity when you press and release pedal. Should change from Open to Short.
If not, take it to a Tech.
Nov 08, 2017 | Yamaha Dtxpress Iv Special Electronic Drum...
I Have a Yamaha dd55c electronic drum machine without the bass and Hi-Hat pedals. I am good with electronics and wondered how they are wired, or alternatively if they are available to buy from anywhere.
The pedals are domes with Piezo disc sensors. SImple two wire connection... the original pedals are really NOT very good... You might try to find regular pedals used for drum sets... they have a beater and sensor. They do cost a bunch.
May 07, 2011 | Yamaha DD55C 7-Pad General MIDI Digital...
I'm trying to use the pads of my Yamaha DTXplorer drum kit as triggers for the sounds stored on my Alesis SR-18 drum machine. I have seen that Alesis markets a trigger module of their own which they...
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
Mar 09, 2011 | Yamaha DTXplorer 5 Electronic Drum Set
The base peddle sometimes doesnt register or goes off just a second after i press it. When no other pads are in use it works fine. Any advice on what i should do. Im experienced in electronics and im broke...
The bass pedals (domes) are really cheesy...consider getting a regular pedal/beater/sensor like they use on the electronic drum sets... that is what I am doing.
Nov 17, 2010 | Yamaha DD55C 7-Pad General MIDI Digital...
My Yamaha electronic bass pedel is not working. If I unplug the connection to the computer and plug it back in I will hear only 1 sound of the base drum. Could the base pedel round pad which is hit by the...
There is a piezo sensor behind the pad typically. This can be dislodged or damaged. FIRST check your cables and try plugging the bass into another inout and see if it will trigger that sound. If not, you will need to repair the bass pedal.
SOME pedals have a sensitivity control which is a tiny pot accessable through a hole... this too is easily damaged if wrong type screwdriver is used to adjust it.
be sure and check for a broken cable, especially near the ends.
Sep 22, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Weak LCD Display on a Yamaha DTX Electronic Drum Kit
NOT a battery issue.
Note that many of these devices have a parameter one can set for "contrast" or "viewing angle". You might want to check your owners manual for this possibility.
I downloaded the DTX manual and there IS a contrast control on the back of the unit near the top left facing the back...
IT MAY require a screwdriver to adjust it.
Apr 03, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Sampling into yamaha dtxpress iv
If you have a sampler, you could midi out of the DTX brain into the midi in of the sampler to trigger the sounds. If not ,try downloading KORE2 from Native Instruments onto your computer and triggering it using the above mentioned method . Midi out from your brain to Midi in on your computer. Hope this helps.
Jan 13, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
Yamaha Dtxpress III Electronic Drum Set S-O System Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
