Question about Nokia 5500 Sport Cellular Phone
Hello! I can't start my phone, when I turn it on screen comes white and turns off imediatlly, but saddenly after a break it starts , what is the problem?
My samsung propel will be on but the screen will be completely white. i can turn it off but when it turns back on it is still white. ive tried calling it and it will work but the screen lags and then turns...
The problem with your phone is just flex problem, the flex on the screen of your phone is weak or worn out, this is a common problem among slide or flip phone.
What you need to do is to replace the flex on the screen of your phone, you can get this done by going to any local phone repairer within your vicinity to help get it fix or replace.
Once the flex is replace, your phone display problem is solve and the screen will start displaying.
Take care.
Aug 04, 2010 | Cell Phones
My phone turns on but nothing comes up on the screen at all, its just black, i can still do things like get into the music so the phone is still working, but the sreen (display) is just black, i think i...
Take care.
Aug 04, 2010 | Sony Ericsson Walkman® W995 Cell Phone
I start up the phone & gives blank white screen
Your Firmware is going damge due to break installation or what ever. but solution is that you attached your device with computer and upgrade software via NOKIA PC Suit. but remember don't break usb cable and power off pc during upgrading or installation on your handset.
Jul 17, 2010 | Nokia 5220 XpressMusic Cellular Phone
My samsung gravity screen is white, when its on you can only dial a phone number and call but the screen is still white no matter what. ive turned the phone off took out the battery, but it still doesnt...
The problem with your phone screen is that the screen of your phone is bad that is why your phone screen is white.
All you need to do now is to get a brand new screen on your phone and you will see that your phone screen will start to display.
I advice you go with the phone while going to get the screen in other to get a the exact screen and a working screen.
Replace the screen of your phone and your phone screen will start to display.
Take care.
May 16, 2010 | Samsung Gravity SGH-T459 Cell Phone
My samsung screen is white but it works ive tried everything, this hbas happen before screen going white and the battery had to be without juice to come back. it works but ithe screeen is white
hi, the main reason the screen turns whits is due to the thin ribbon that sends the data from the circuit board to the screen being damaged what happens is that the thin copper wires that are inside the ribbon ware and then break causing a short to the screen and this is what turns the screen white. this happens on most flip and slide phones as the ribbon moves when you slide or flip the phone so over time it becomes brittle and you lose the connection and this turns the screen white.
sometimes it will right itself if you open and close the phone a couple of times but this wont be a long term fix how ever it may be that bad that this will no longer work, its not expensive to get this ribbon replaced but taking you phone to a small phone shop would be your cheapest option.
May 14, 2010 | Sony Ericsson K800i Cellular Phone
The screen will turn white and freeze up
how to fix my verizon wireless cell fone when the screen turns white?
Sep 20, 2009 | LG VX5500 Cell Phone
Why does the screen on my Samsung M520 turn white?
the problem comes from the led film behind the screen. There is absolutly nothing you can do about it now. When you got your fingers all over the screen by sliding it, it starts to break. It isn't going to get better, probably only going to get worse. the only thing that you can do is buy anotherone im afraid
Jun 14, 2009 | Samsung SPH-m520 Cell Phone
Screen has turned white no display
my screen is not appearing it started last four moths after some few minutes the time comes and when any of the key pad is pushed sudden it will vanish and the screen turns white.
Jun 08, 2009 | Sony Ericsson K750
Hello, some times my computer just shotting down unexpectedly. Few min ago it went to blue screen all of a sadden with fuzzy righting and then in about 7 sec it shoot down and started restarting on it's...
The blue screen comes becoz of unexpected shutdown...If it comes more than once then ur system files may be corrupted ...Try to reinstall Windows...
Nov 29, 2008 | HP Computers & Internet
Nokia 5500 Sport Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
