Question about Troy Bilt Pony 6.5 Hp Rear Tine Tiller
PTO making noise when engaged in forward drive
I am using my dad's tiller - horse model, ser 646564 and it started making a noise in PTO forward only while I was tilling my flower bed. Depth setting was 4th notch. What kind of oil is used in PTO?
  • 3,600 Answers
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Posted on Nov 13, 2009
New tiller makes grinding noise when trying to run tillers
if it has a clutch
most small units just run a dog that you engage with a swift motion at low idle speed of the motor
have the tillers free above the dirt so they can turn with out any load to inhibit the dog engagement
May 20, 2015 | Garden
My new PTO belt has too much play when not engaged, gets off track
-Adjust the engine forward a little until it's good.
Good luck
Mai
Jun 25, 2014 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
John deere 2210 engine dies when engaging pto, seat switch good
are you sitting in the seat or have you jumped the safety switch under the seat before you engage the PTO I believe our tractors use an electric solenoid to apply hydraulic pressure to a wet clutch inside the trans axle I would think it would be OK with your chipper I have a 450 tiller that was built for the older 400 models 425 445 455 that I now use with my 2210 If I hit a large root or stone when using it with my old 445 it would stall the tractor at full power. Now with the 2210 it will actually slip the clutch on the tiller s PTO shaft I think the correct approach would be to increase your RPM s gradually or start increasing the power just as you trip the PTO switch. You want enough RPM s to create enough hydraulic pressure to run the PTO circuit so that you don t slip the wet clutch anymore than necessary and you want the RPM s low enough so that you don t shock the mechanical systems too severely at start up
Let me know how it works
Feb 02, 2012 | Garden
4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 25, 2010 | King Kutter II Gear Driven Rotary Tiller...
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tines wont turn /disengaging type grinding noise
its possibly the gears inside the box they are spider gears & wearout on those they are great machines but the gear drives are weak most of the time or the belt could be slipping
Jun 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
Jan 17, 2009 | Troy-Bilt Pony Garden Tiller
Troy Bilt Pony 6.5 Hp Rear Tine Tiller Logo
275 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
