How do I get my GE agitator out? model #WJRE5500G1WW
  • 460 Answers
I will be very happy to assist you in this issue.
http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
i hope this answer your question
your rating and comment its very important to me
thank you
Posted on Nov 14, 2009
How to remove agitator
That is a very old GE model. There may be a screw under the agitator cap which needs to be pried off. Even with the screw removed the agitator usually rusts or bonds to the transmission top. GE had a special pulling tool that was a metal ring that fit over the agitator with 3 set screws in it that you had to screw into the outer plastic of the agitator. A gear puller was then needed to pull the agitator off. Don't know if its worth it considering the age of the machine.
Apr 14, 2016 | GE WBSR3140DW Top Load Washer
GE washer agitation starts normal the progressively slows and then stops agitation. All other modes work fine. Model # unknown. Motor or transmission? Thanx people!!!
Model # located on the back of the control box of top load, just inside of door on front load. Other Op modes ok, problem points to agitator support shaft or the belt drive of the agitator.
Nov 17, 2015 | GE Washing Machines
GE model WWA8320GAL How to I get the agitator to come off. Thanks for any advice art
Please read this link below first before you try to remove the agitator.
http://www.geappliances.com/search/fast/infobase/10002927.htm
This link below will tell you how to remove the Agitator on the ge washer.
Jul 07, 2011 | Washing Machines
We have a ge washing machine model number WJRE5500G1WW. We were starting a new load of laundry and the washer was just filling with water. There was a loud noise we stopped the machine and it looks as if...
We have a ge washing machine model number WJRE5500G1WW. We were starting a new load of laundry and the washer was just filling with water. There was a loud noise we stopped the machine and it looks as if the entire central component that holds the washer separated from the metal shell. It is no longer suspended from the outer support framework
and is floating unsupported. Do you know what we should do to fix this
May 13, 2010 | Washing Machines
Ge wjre5500g1ww. My washer will do the cycle but at the end the softener is till full and the cloth still soak wet. Any way to fix this issue?
Try this:
Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. Put the machine in a spin cycle and see if it runs.
Mar 26, 2010 | GE Washing Machines
How to remove agitator from GE washer? Model WHDRR418G1WW.
how to remove agitator from GE hydrowave washer machine?
Feb 27, 2010 | GE WBSR3140DW Top Load Washer
Ge washer M#: wjre5500g1ww will not fill
First, make sure there's water getting to the washing machine. if the hoses are not kinked and, the water is reaching the unit, replace the water valve assembly.
Jun 19, 2009 | GE WBSE2090A Top Load Washer
AGITATOR REMOVAL GE WASH MACHINE, MODEL WPSR3100
If you remove the top cover to the agitator, inside you will see a I believe 9/16" nut.  Remove this to take the agitator off the shaft.
Mar 12, 2009 | GE Profile WPSR3100W
GE top loader not agitating
Your agitator splines are probably stripped out.
Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
Mar 04, 2009 | GE WBSR3140DW Top Load Washer
Ge elite 110 23012 100 top load washer
look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Aug 08, 2017 | GE Washing Machines
Washing Machines Logo
154 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
