Question about Siemens Ovens
Broken oven light cover
The light cover (glass surround) in my oven has cracked and fallen off. The light is at the top of the oven, above the grill. Is it dangerous to use the oven without a cover on the light (will it short circuit?)
SOURCE: Loose Oven door handle
can get spares from
Tel. 01628 620081 Fax 01628 776345 - Spares Email is spares@a1tech.co.uk
Posted on Apr 14, 2008
SOURCE: top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Posted on Oct 08, 2008
  • 1462 Answers
SOURCE: Glass in oven door is cracked, inner glass completely fallen out
this is a fairly common problem with glass doors on any make of oven
Posted on Oct 21, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
FixinFax
  • 3085 Answers
SOURCE: the inside glass has fallen out of the door.
http://ovendoorglue.com/?gclid=COaliI3t558CFYNo5QodvVPJHg
I have used this stuff, and it does the job.
Posted on Feb 10, 2010
Glass panel missing on grill (top oven) door?
if there seems to be a hole there and not a solid door then yes there should be glass there. try doing a goggle search on the brand . there might be a pic there to show you what is should look like.
Nov 12, 2011 | Ovens
Hi, I have a Neff oven Model No B144 2N0GB. The light has blown but I am unable to remove the glass cover to replace the bulb. It appears as if the glass cover has fused into its surround because it...
If the unit is less than two years old, cal 0844 892 8999 and ask for an engineer to come out. Alternatively, put on a pair of marigolds, this will help with the grip and remember that the cover comes of anti-clockwise if you are looking up at it. If you do not want to call an engineer out, call the number above and ask them to post out to you the lamp cover removal tool. Part number 613655.
All the best
Sep 01, 2010 | Neff B1644 Electric Single Oven
The glas bulb cover at the top of the grill/top oven has broken leaving the glass edge stuck in the thread. I have a replacement but cannot get the old remnants out. Do I have to call an engineer to...
take a wooden stick about the same diameter as the broken bulb; place a washchoth over the end; push the stick into the bulb base in the oven and, turn the stick counter clockwise until it comes out. the stick is an insulator so you won't get shocked and, the cloth grips the bulb base.
Jul 31, 2010 | Bosch HBN 9061 / HBN 9021 Double Oven
The grill element has fallen down because the two
What you need to do is obtain 2 large self tapping screws,and resecure the element to the top that way, or failing that , fit 2 cavity wall screws, these will also do the job, but you may have to enlarge the holes.
Apr 06, 2010 | Zanussi ZDQ695 Electric Double Oven
How do I replace the lightbulb. NEFF B1442 series 3 Oven
1. Some glass covers are held on with a wire clip over them. It should be visible.
2. Some have a 'ring' which is screwed to the oven cavity around the light cover. On that design the screws need to be removed from the surrounding retaining ring.
3. On may later model the glass light cover screws into place. Those covers should 9hopefully) be able to be unscrewed the same you you'd remove a jar lid.
Nov 07, 2009 | Ovens
Grill control knob broken
hello sir/mam
please check the back portion of the oven you will see the screws which will be fixed to the top cover you should unscrew the screws and using a screw driver push the top cover .Then you can fix the control knob.
Oct 04, 2009 | Smeg DO 10PSS Stainless Steel Electric...
I cracked my stove's ceramic glass cook-top
replace the glass. it may be expensive but usually fairly easy
Jan 04, 2009 | Ovens
Oct 21, 2008 | Whirlpool RBS305PD Electric Single Oven
NEFF Oven
brute force i'm afraid. try using a pair of mole grips. its not the end of the world if you break the glass
Oct 02, 2008 | Ovens
Ovens Logo
159 people viewed this question
Top Siemens Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a Siemens Oven Expert? Answer questions, earn points and help others
