Question about Advent 4211c Notebook
It runs fine on mains power but will not run at all on battery despite apprently being fully charged.
  • Dheeraj Pundir May 11, 2010
    how much time before you purchase the laptop & what are the usage hrs / day
    Problem Solver:
  • 10 Answers
Your battery cell unfortunately seems to have run dry. The most favorable solution is usually to get a new battery for your computer.
Posted on Nov 13, 2009
Will not run on battery. charged battery but will not hold charge.
Hi Martha, had a bit of a look around and noticed a few mentions of charging problems including the following - 'One of these units was apparently dead on arrival and on further investigation, it worked off mains but not from battery. The battery comes out from a flap underneath the unit, and on testing with a multimeter, it was under voltage, so must have been old stock. Despite 2 days of charging, no life, so I ordered a replacement battery (RITAR RT1250 or equivalent 12v battery) and it works fine. I also have a proper battery charger rather than use this unit's own charger, which charges the battery rapidly, but I think at the cost of battery lifespan. Given that I use this unit infrequently, this is fine, otherwise use the internal charger as normal. With the new battery, I've never managed to run out of battery.. it will keep going all day on a single charge.
The manual does state that if you don't charge the unit at least every 6 months, it may not charge.'
I know it's not exactly a resolution but hope it helps!
Jun 16, 2015 | ION Audio Tailgater Portable Pa System For...
Battery is charged, but laptop cannot work without mains
You need to install a new power/sound board. These boards go dead on the early Intel MacBook Pros for some reason.
Oct 19, 2011 | Apple MacBook Pro - Core Duo 2.16 GHz -...
250 z kawa 82 ,runs but won't charge battery, has had battery connected wrong way. any ideas,has apprently been to auto elect, but no help.
It's possible that when the wires were connected the wrong way it could have caused a short in the electrical system that charges the battery. I'd suggest you change those first.
Mar 14, 2011 | 1982 kawasaki Z 250 C
New battery was fully charge but not working
M35x's had a massive recall regarding the motherboard and battery. unfortunately it sounds like your motherboard is failing
Oct 17, 2009 | Toshiba Satellite M35X-S149 Notebook
The battery light remains on unless the power
If the computer will run on battery alone, and you cannot fully charge the battery, it's probably time for a new battery. The life expectancy is 2-3 years if treated right. Some people get a lot more life than others.
Here's a suggestion: when you run your computer, let the battery run fully down at least once a month. Do not leave it plugged in to line power all the time. Do not keep charging it when it is only a little bit discharged.
Jul 01, 2009 | Dell Inspiron 6400 Notebook
The computer will only run from a fully charged battery.
friend
the problem clearly shows the fault is in the motherboard
thanks
Apr 10, 2009 | Toshiba Qosmio G35-AV650 Notebook
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Discharges very fast
it may be ur battery problem may b u replace ur battery or minimal use of display settings.,n regarding the reconizing of memory card..it may work wit some reboot method..stil check out ur battery first.....try it..if it works do rate me
Apr 06, 2008 | Motorola Mobility A1200
Advent 4211c Notebook Logo
178 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
