Question about OKI C3200n Led Printer
When I print to my Oki C3200n the paper comes out with a giant crease in it. The fuser was replaced and the problem still persisted. Are there any other possible solutions?
  • kmckinnon Nov 13, 2009
    Thank you! The only reason I mentioned the fuser was because the solutions to other similar problems involved it.
    Brigadier General:
  • 10,406 Answers
The "fuser" uses heat to "bake" the ink onto the paper.
Your printer seems to have a mechanical problem while "feeding" the paper from the "input" tray, through the printer, passing the fuser, and to the "output" tray.
Check that all the rollers that "pull" the paper into the printer are working -- if one of them is not grabbing the paper, the paper "slews".
If you need help, take the printer to a qualified technician for repairs.
Posted on Nov 13, 2009
How do i print borderless
you cant. laser printers (or led like oki) or more specifically dry toner electrostatic printers always have a margin to prevent the paper from jamming. the only way to print "full bleed" is to put paper in that is bigger than what you need, print the image, and trim it down.
Sep 17, 2014 | OKI C3200n Led Printer
Why does paper keep creasing up
can I get a little more info what do you mean creases is it jamming or just coming out crinkled if it makes it through the machine check the guides and the paper type the tray is programmed for if it stops around the fuser and folds like an accordion replace the fuser
Aug 05, 2014 | Kyocera Office Equipment & Supplies
On my oki 5150 the printed paper develops a crease usally in the middle of the page. Usually about 4 inches long, with a small overlap that ends up in a crease ... it's starting to get sufficiently bad so...
If the paper under the crease has print and the fold is "glued down", it is most likely to be a problem with the fuser. Try removing it and look for evidence of warping in the pressure roller. If the fuser looks clean and tidy, go to the other end at check over the paper tray and paper feed mechanisim. It is possible the paper is catching on something at the start of the process. This is most likely if there is print over the crease but not under the fold.
Jan 01, 2018 | OKI C5150n Led Printer
310, 311 318 paperjam can not find it
is the paper in the fuser, try turning the fuser, sometime there are some small pieces of paper stuck in between the fuser and pressure roller
Feb 18, 2010 | OKI C3200n Led Printer
Oki C3200 message on screen says '171 Fatal
Yes it can be saved, it is indicating the fuser thermister is open or below temperature. Try opening the printer and restarting it. If that does not fix it you may have to replace the thermister or the fuser
Jan 18, 2010 | OKI C3200n Led Printer
Okidata C3200N
It would help if you said where the paper jam was. However the fact that it was ok until you cleared the jam indicates you have knocked something out of place. Its just possible one of the high voltage contact springs that touch the drums has stuck in and no longer makes contacts with one of the drums. Make sure all the semi circular springs move in and out freely. Also check the led heads in the top cover. Make sure all the cables are seated in the heads ok. Make sure all the heads are in the same position and one has not turned around. Retrace your steps as your drums seem to be problem.
Jun 25, 2017 | OKI C3200n Led Printer
OKI c3200 Laser Printer...
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Apr 07, 2008 | OKI C3200n Led Printer
Printer
High moisture content in paper,
or fuser (ie hot bit rear) needs replacement the orange fuser pressure rollers are wrinkled or worn.
Jan 09, 2008 | OKI C3200n Led Printer
OKI C5250 Printer
My informed guess without seeing print sample is that your oki needs fuser unit replaced. Look at orange rollers should br smooth no wrinkles.
Dec 20, 2007 | OKI C5200n Laser Printer
OKI C3200n Led Printer Logo
370 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
