Question about True GDM-49-RC Refrigerator
Light flickering-it won't turn on.
I just replaced the bulb on my GDM-49 refridgerator and it only flickers dimly. Any idea about what could be causing this problem?
  • 2,237 Answers
Starter cap in the light base. usually a silver metal or white plastic can. twist it to unlock it and pull it straight out. replace it with the exact type. you can get them at any hardware store. if your light doesn't have one, you'll need to replace the ballast inside the base. if the hardware store does not have one, you'll have to look online. try www.partselect.com.
Posted on Nov 13, 2009
Tip
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
on Dec 18, 2009 | Honda Civic Cars & Trucks
WHEN ON DIM THE LIGHT FLICKERS
That is because the dimmer is designed for incondescent lights and you are using compact fluorescent. To solve the flickering problem add at least one regular bulb to the system. If there is only one bulb then replace with a regular bulb if you are using a dimmer.
Apr 30, 2013 | Lutron Electronics Toggler Preset Dimmer,...
The bulb is flickering. I have replaced it but the new one also flickers
replace the ballast I can send you one cheaper than you could purchase it I have 100s of them in storage always a ballast if they flicker
Apr 10, 2013 | Verilux Modern Deluxe Natural Spectrum...
GDM-49
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
Go to the above web site. It should be the installation manual for your unit. It has lots of good stuff.
Hope this helps
Nov 13, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Flourescant lights flickering
is there a ballast or a starter? if there is a starter (little silver metal or white plastic can), then replace the transformer inside the lamp housing. if there is a ballast (long black rectangle with many wires) and you replaced that and the lamp, then there must be a power drain in the unit somewhere.
Aug 25, 2009 | True GDM-12 Refrigerator Commercial
True GDM-49-RC Refrigerator Logo
175 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
