Question about Samsung SGH-A877 Impression Cell Phone
My screen goes blank once I drop down the keyboard because I hit a button but the touch screen stil works so I know screen is not out.
How to activate touchpad on acer e1-571
Hi
One of the toggle switches using the FN key turns the touchpad on and off.
<Fn> + <F7> Touchpad toggle. Turns the built-in touchpad on
and off.
If you go here :-
Drivers and Manuals
and selecting your model from the selections offered ie "Notebook" then "Aspire" then "Aspire E1-571" you can find all the documentation, drivers, applications, BIOS etc for your machine.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 16, 2014 | Acer Aspire Computers & Internet
I touched a button on the keyboard that turned the page sideways.. it turned it to the left. how do I turn the page right side up?
Actually you hit a combination of keys. Most likely you hit Ctrl+Alt and an arrow key. Try Ctrl+Alt+the up arrow. If that rotates the screen to upside down, repeat the combination twice more (or use Ctrl+Alt+the down arrow twice).
If that doesn't work, if you have a Windows OS, try the Screen Resolution or Graphics Display settings. Right click on the desktop anyplace with no running programs or icons, select Screen Resolution and then change the drop down for Orientation. This works on my desktops. For my laptop, it's the Graphic Display and then a similar orientation label.
I hope this helps.
Sep 10, 2013 | Logitech Y-RAZ71 Wireless Multimedia...
My Laptop will not start up goes to a blank screen.
Try running Last Known Good Configuration which should fix your problem.
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows. I
Jan 16, 2011 | Acer Aspire 3680 Notebook
Acer 5536 boots up goes to screen to select safe mode, tried both modes but after the selection screen goes blank with a little loading circle but goe sno further, no log in screen or anything, please help
Follow the steps below,
Nov 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
Keyboard locks into all CAPS
Just a thought...one time I had a button that kept stiking itself with out me touching it...I removed the keys aroud it, only to find a tooth pick had found its way into my keyboard. Everytime I would hit any of the keys around it, it would also hit that button too. Dont know if this is your problem but worth a look!!
Sep 18, 2009 | HP D8597A Keyboard
Everything gets highlighted and the mouse goes to a split screen
hi,sound like you are hitting the scroll wheel button, down once put a split screen to show you what you are working on. these are settings you can change to your preference with the intellipoint software on the disk,or download from the microsoft hardware website. be advised this software is for microsoft hardware only. hope this helps, good luck! glen
Dec 10, 2008 | Microsoft Wireless Optical Mouse
Hard reset for a HTC Touch Diamond
To perform a hard reset
1. Pull out the stylus.
2. With the device turned on, press and hold the VOLUME DOWN and
ENTER buttons, then press the RESET button with the stylus tip.
3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen:
4. Release the VOLUME DOWN and ENTER buttons, then press the
VOLUME UP button to perform the hard reset, or press any other
button to cancel the reset.
Clear Storage
You can also use Clear Storage to reset your device back to factory default settings and/or format the internal storage.
1. On the Home screen, slide to the Settings tab and then tap All
Settings.
2. On the System tab, tap Clear Storage.
3. In the drop-down menu, select whether to Clear Storage only,
Format internal storage only, or Clear storage and format internal storage.
4. Enter “1234” and then tap Yes.
Sep 14, 2008 | HTC Touch Diamond Smartphone
Factory Restore
Have you tried using another keyboard? if that doesnt work, try hitting the pause/break button on your keyboard and you should notice that your screen will be stuck on the dell logo with the bar going across, once you notice that hold down ctrl and hit f11. that should work..
Let me know what happens, alright?
Aug 18, 2008 | Dell Dimension 4600 PC Desktop
HP Pavilion Dv6000 with Vista screen goes blank
Sounds like a software issue with the power settings for the screen. Go into the display properties, open the tab that reads screen saver, click on the power button. Adjust the screen setting to never. This should take care of your problem, if it doesn't then it may be a loose connection on or around the screen. CHeck the connections.
Jun 19, 2008 | Computers & Internet
Keyboard S 530 Mac
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Hope this helps. Bud
Jun 01, 2008 | Logitech 967224-0120 Keyboard
Samsung SGH-A877 Impression Cell Phone Logo
423 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
