Question about Sony Ericsson T610
Turn on w/out using the usual switch
My T610 felt down and the on/off switch is broken.
Is there any other mean to switch it on without using this switch (some "magic" keypad combination) ?
  • Schnockeloch Jan 08, 2008
    Sigh ! When I connect the battery loader, the screen lights on which
    means that the CPU runs and so on. I hoped that there could be a mean
    to switch to active mode at that time. Too bad !
    Impossible to shorten the switch : the printed circuit board is damaged at the switch place.
  • 192 Answers
Power on process in mobile phone always need mechanical switching. There is no other way to power on it and put it in active mode. You have to repair that switch or shorten it for minimum 0.6 seconds to wake up the phone. Is it understable and fixing your problem....Vote FIXYA for that...
Posted on Jan 08, 2008
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
I have hp t610 plotter and it incurred paper jam
Check the carriage belt for wear. Is there an error code?
Aug 19, 2013 | HP Designjet T610 InkJet Printer
I have a programmable thermostat that I set to 68 at night. The system turns on and runs, but when I woke up this morning, the tempterature in my house was 58. I felt near a vent and it felt like it was...
Hello, sounds like the units high limit switch is opening and shutting down the burners. When this happens the blower motor and inducer motor will run nonstop....and this is why you probably just felt cool air blowing from the air duct. Usually a dirty filter, blower wheel or weak blower motor can cause the units limit switch to open.
Dec 01, 2011 | Heating & Cooling
HPdesignjet T610 error code 08:11
The 8 code is a formatter or front panel problem. Try reseating the formatter and its cables. Also reseat the front panel cable.
Basically it means that there is no communication between the front panel and the Main board. Turn the printer off and unplug it from the wall. Reconnect the cord and power up. If it still fails, the formatter or the main board or the front panel will have to be replaced. Get a tech to check it out.
Oct 31, 2010 | HP Designjet T610 InkJet Printer
Hp designjet t610 error 01.1:10
Explanation Problem with the PrintMech PCA. Recommended action Try the following:
  1. Turn the printer off (using the power switch at the back of the printer), and disconnect the power cable. Wait 15 seconds and reconnect the power cable and turn the printer on.
  2. If the error continues, call HP for support.
Sep 24, 2010 | HP Designjet T610 24-in printer InkJet
I want to delete all the contacts on the phone but
sir ,
first of take out ur sim card from mobile and switch off ur mobile phone . then again switch on ur phone ur phone will open in offline mode thenallcontact will be appear will be in phone memory . so now use "delete contacts" option .
Jan 22, 2010 | Sony Ericsson T610
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Free download how to upgrade software of the sony ericsson t610
Sony-Ericsson site reports that " The T610 does not support the Update Service application." This means you'll have to find a third party application and firmware supported by the third party application for the T610.
Nov 30, 2008 | Cell Phones
Frigidaire dryer gets clothes caught in between the drum, and body of dryer
Just did this today! The brown marks are the felt that is around the part that suspends the drum. It has probably been making a rubbing noise for awhile? The mechanism that supports the drum and allows it is spin is called a bushing This is no longer balancing the drum properly so it is rubbing against the felt and wearing the felt down. The brown marks are burnt felt rubbing off onto the clothes. Get a new bushing assembly and either a top and or bottom felt replacement kit. Replace all worn felt! The top felt has either two or three plastic gliders on it as well. It has been an all afternoon job for me. A second pair of hands is also helpful so long as you are not married to them! Good luck...(I paid $90.00 for a top felt, bottom felt, and a whole brand new bushing unit.)
Feb 18, 2007 | Frigidaire FER231A Electric Dryer
Sony Ericsson T610 Logo
71 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
