Question about Linksys EtherFast Cable/DSL Router
Befsr41 v4.2 power led's blinking.. already tried to hard reset but it's still blinking.. it's happen after i upgrade firmware to the newest (2.00.4 build 5) (the fw upgrade message is succesfully upgraded but it's blinking after that)
  • Linksys Master
  • 8,404 Answers
Hi there. I have this same device. I tried everything that can be tried, including replacing the device. Replacing the device worked.
This solution may work for you too.
Posted on Nov 14, 2009
Power led is blinking after I upgrade firmware
Something went wrong during the upgrade of your firmware. If you were upgrading the firmware from Linksys website you need to call their tech support and have them replace it for you. If you were trying to hack it with a 3rd party firmware you probably need to go buy another one and maybe consider using the firmware it comes with. You cannot restore the device because the flash killed the restore function. Your device is cooked. Put some BBQ sauce on it and serve it for dinner.
Jan 03, 2010 | Linksys WRT54G2 Wireless Router
I have a quicksilver power mac G4 desktop that has a blinking green light when I turn it on. What should I do?
I assume the light you refer to is the power LED.
No Apple tech repair guide says anything about this LED being able to blink.
It's possible that this is an indication that it is trying to upgrade firmware, especially if it is accompanied by a loud audio tone of about three seconds. I can't say this for sure, because it has never been necessary to activate the firmware upgrade mode on a Quicksilver, since Apple never released any firmware upgrades to it. Firmware upgrade activation is achieved by holding in the power button at startup until the tone is heard. If you are hearing the tone and the power LED is blinking, it may simply indicate that your power button is sticking in.
Dec 27, 2009 | Apple eMac G4 Desktop
Losing connection constantly, when I hok up computer directly to the modem I have no problems, but with the router my internet does not work. The lights on the router are flashing and indicate that it is...
have you done a chat with Linksys? What do you use to manage your network?
May I suggest you get Network Magic, a free download and eval period.
Using Network Magic, you may find you have settings on the router that prevent your getting past your 'fire wall'.
Oct 12, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
DWL 2700 AP wrong firmware install
hi...
since you upgraded a different firmware try updating the firmware again with the correct firmware if it works fine if it doesnot then the router had gone bad,,
and for GeminiBS reset the router to the factory default since the firmware was not done in a proper manner may be it had interruptions..once the hard reset is done the computer is restored back to the default so that you can use the device..
vedhick
Feb 13, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
Router suddenly dropped connection. Have been using this same router without issue for about 8 years now (Linksys BEFSR41 router). When I tried resetting the router and plugged the power back in, the power...
If the power light keeps blinking it means that the router has reached its end point or else you have short circuited the board, or the router is reached up to the maximum whereby it has totally failed. The best would be to replace that router now or try to use a software named tftp to get into the router interface if it is possible then upgrade the firmware/ You can get tftp by searching in google.
Jan 21, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Power indicator keep on blinking
hello!
blinking power light after firmware upgrade sometimes indicates that the upgrade is not sucessful or the firmware that you load is incorrect.
-- try to reset the router for 30secs and check if the power light is still blinking
-- if its still blinking check your pc's ip address while connected to the router
-- if the ip address of your pc is invalid (169.x.x.x.) turn to manually assign static ip address to your computer and check if you can ping your routers ip address
-- if you can ping the routers ip address, upload the correct firmware to your router
-- if you cant ping your routers ip address still, reset the router again and try to ping the routers ip address once again
-- try to change port and cables
-- if still unable to ping the routers ip address, chances are that the router might be defective now
Apr 29, 2008 | Linksys Wireless-G WRT54GS Router...
D-Link DI-624 wireless router is not working after firmware upgrade try
Try to unplug the router and hold in reset button for 30 seconds see if that works, you probably did that already, But if you can get your computer to respond you should be able to open software Bios. and do your firmware update from there. If not I believe a hard reset is with the router plugged in and holding reset button for 30 seconds, I don't know I sure hope that resets it for you. Thanks take care
Dec 23, 2007 | D-Link DI-624 Air Plus XtremeG Wireless...
Diag led
wat about the powerlight in the router....
Oct 24, 2007 | Linksys Wireless-G WRT54G Router
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: http://knowledgebase.3com.com/ OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
Linksys EtherFast Cable/DSL Router Logo
278 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
