Question about Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-S209 (PSA70U-09700E) PC Notebook will not start.power lights come on for both the battery and DC. There is no fan or hard drive sound.power button does not light up. pushing the button below the power button turns fans on briefly. Occasionally can get blue light on power button to light up simultaneously.
  • 1 more comment
  • dcjerome Nov 13, 2009
    I get the same result with the battery in or out except the power light for the battery is off when the battery is not in of course. The RAM is nonremovable.
    I do not mean to seem obstinate but there is 512 onboard memory and one open memory slot to which you are alluding.
    Another question would be good the onboard RAM be bad?
    The power adapter appears to be intact and wiggling it does not change anything.
    If the onboard memory is bad if I purchase some additional memory would it bypass the problem?
    Besides the motherboard could the CPU be bad?
  • Toshiba Master
  • 4,806 Answers
Take out the battery and try booting the machine on AC power only. If the machine boots up then let the operating system load up, the shut it down. Remove the AC jack and put the battery back in again, then power it up.
If it boots all is well if it doesn't then there could be a problem with the battery.
If the laptop won't start on AC power, what you could do is remove the system memory, clean the brass pins and the slots and then re-seat them/it.
Then try to turn the machine on.
Good luck.
Posted on Nov 13, 2009
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Nov 13, 2009
    The memory is removable. It is located underneath the laptop behind the WiFi/Memory bay cover behind the battery.
    All you have to do is unscrew the cover.
    The memory looks like this >>>>>>
  • Lee Hodgson
    Yes it could be the on-board memory.
    Try checking the power adapter on the laptop. Plug in the power jack and wiggle it to see if there is any play. If there is then the adapter maybe faulty and needs to be replaced.
    If it's not loose then you are looking at a possible failure of the motherboard itself.
  • Lee Hodgson
    Sorry I didn't make myself clear. I meant does the power adapter feel loose inside the socket?
    Adding more memory in the spare memory slot won't make any difference as the on-board memory will interfere with the operations.
    Being a computer technician there is one more thing i would check out before i resign my self to serious internal failure. that is to clear the CMOS.
    I cannot remember exactly where this is but what your looking for is a jumper called j1 on the underside of the motherboard. The jumper is usually under the WiFi cover (remove WiFi card) or the memory slot. Sometimes they are coverd with Mylar (black or clear plastic) so you may have to peel it back.
    When you find the j1 jumper get a flat headed screwdriver and short it. the best way to do it is with no power connected at all Including the battery, hold the screwdriver in the short position and press the on button.
    You can always do it with the battery in as well.
    Good luck.
How do I do a complete restore on a Toshiba Satellite A75-S209
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Aug 21, 2012 | Toshiba Satellite A75-S209 Notebook
Wanted Toshiba Satellite A75-S209 17"
I had an old thinkpad that i needed a screen for...i believe I ordered it off ebay...and it was under 100 dollars...go to ebay and try it
Jun 11, 2011 | Toshiba Satellite A75-S209 Notebook
Is this laptop windows 7 compatible?
Hi, Your laptop:-"Toshiba Satellite A75-S209" is compatible with the Windows 7 operating system. Thank you for your time and best wishes for your effort.
Jan 06, 2011 | Toshiba Satellite A75-S209 Notebook
A brobblem with my chrger
Here is the replacement Toshiba Satellite A75-S209 A75-S2112 AC Power ..
Part number: PA3290U-2ACA, or PA3290E-2ACA
Dec 20, 2008 | Toshiba Satellite A75-S209 Notebook
Satellite A100 won't swich on- will be similar to A75
remove the battery , then insert it again, then leave it for charging for some times then check
Oct 26, 2008 | Toshiba Satellite A75-S209 Notebook
Video on Toshiba Satellite A75-S209
check the display on external monitor through the vga port of the laptop,
Jul 17, 2008 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-s209 Laptop
The toshiba laptop has ways of checking if it will not charged
check the battety light if it coming on when it is plug in
If the not meaning the battery is bad
If the lights comes up and the computer is still not charging the battery test if the compter will power without the battery if it will then battery is bad
If the computer will not turn on even the lights on the panel shows activity then you can conclude that the AC adpter is bad
Jul 15, 2008 | Toshiba Satellite A75-S209 Notebook
Open Questions:
Toshiba Satellite L15-S104, Model PSL10U-01X02F--A COMPLETE LEMON! 2-14-08 I purchased a Toshiba laptop in May 2005 at Best Buy in Montclair, California and all was good for a short time. Less than a year later I began to have so many problems. I took laptop to Best Buy Geek Squad and the hard drive had to be replaced! I had an extended warranty, so not any cost to me. I continued to have problems with the laptop and in took my laptop back to the Geek Squad in January 2008 and was told the laptop needed a motherboard at the cost of over $600! The warranty had ended. I have called Toshiba apx 4 times and finally given to a case manager and left on hold each time from 10 to 17 minutes! I have left messages and not anyone has returned my call. I have requested that my laptop be replaced. Christine Honea-Takata CHoneaTakata@msn.com Ever since I bought my laptop in December of 2004, I've had nothing but problems. My laptop overheats and shuts down repeatedly, the screen freezes, my sound only works 75% of the time, etc, etc. I have a stack of paperwork from the Geek Squad for numerous repairs - they've replaced everything at least once, some parts multiple times. They finally told me it was a lemon and that they were sending it in so that I could get a new lap top....6 weeks later I hadn't heard anything and called them - the usual waiting on the line, talking to 4 different people, them saying they'll call me back. A few days later I still hadn't heard back from them so I called again - same run around. They then told me that my lap top wasn't a lemon and that there was nothing they could do for me. I bought an extended warranty (3 years) and it's been in every few months - also meaning I'm without my blimmin' lap top for at least 2 weeks at a stretch. After my warranty ran out, I "gave up"...what more could I possibly do? The machine was a lemon from the start but Toshiba won't own up to anything. However, I know there was a class action law suit filed...haven't heard anything about it for the past year or so. I wouldn't touch a Toshiba with a ten foot pole. Terribly disappointed, angry and frustrated. I've lost huge amounts of data and had nothing but problems with customer service.
Apr 06, 2009 | Toshiba Satellite A75-S209 Notebook
Toshiba Satellite A75-S209 Notebook Logo
326 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
