Question about Sony Ericsson W200i Cellular Phone
I was texting and then all of a sudden it froze so i took the battery out and when i put it back in and tried to turn the phone on.. it wouldnt turn on
LG Rumor 2 turning on and off.
First, make sure if this problem appear after you install any APP, if so you can try to brush system to fix it.
Else maybe the following cases:
1, mobile phone motherboard leakage lead the current too large.
2, The inside circuit protection of the lithium battery is too sensitive, so it power off when circuit is large.
3, the battery itself is aging.
4, Battery contacts are dirt-bit, causing bad power supply.
5, The engagement between the battery and the phone is easy to loose bits. (try to remove the back case and press the battery then try to turn on it to see if it also turn off and on). If so, just make a piece of paper to stand the battery up
Of course, don't forget to see if the power button is back to its own place
Apr 08, 2013 | LG Rumor 2 Cell Phone
My phone won't turn on
Sounds like the firmware in the phone is fried. Best thing to do is take it back to where you got it from, and tell them what's happening, they should be able to help you if it's still with 12 months. You could also take it to a repair shop, they may be able to help you.
Lemme know how it goes.
BB
Oct 22, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I was trying to text and my phone froze. Wouldn't turn off so I took the battery out, now it wont turn back on.
Your phone may be cooked. Same thing happened to my cell phone. My service provider replaced my phne on the spot, well ... when I got to their store they replaced it without question.
a
Oct 02, 2009 | Sanyo SCP-2700 Cell Phone
My motorola rokr wont turn on!
hold the camera button and then turn ON,then check if the phone goes to the flash mode ,the screen would turn completely RED
Sep 19, 2009 | Motorola Mobility ROKR E6 Smartphone
Phone says ''Searching for Service''
try this code but remeber that u will loose every data on fone including sms and call log and contacts.
*#7370# TEHN DEFAULT SECURIYY CODE 12345
Dec 03, 2008 | Nokia 6600
Sony Ericsson W580i phone will not turn on
same thing happened to mine last year--you need to update the software: http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w580i?lc=en&cc=us
your phone should have come with a usb/computer hookup wire (it's gray). Download it onto your phone. It turns out that this same problem happened the other day (so I am downloading it now). it's the only problem ive had on this phone... hope it helps
Sep 30, 2008 | Cell Phones
My K810I froze up.
Now you should take the phone and ahve it reflash ....also you can try online at www.topsony.com
Jul 04, 2008 | Sony Ericsson Walkman W810i Cellular Phone
My phone is dead
go back to your local store that you bought your phone from, they will change it for you or fix it
Feb 10, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Everything is gone
just put the battery back in and once it connects and you have the G up in the top right corner, everything will load back onto your phone. that happened to me today and i was so mad, but everything came back.
Feb 06, 2008 | T-Mobile Sidekick ID Cellular Phone
Wont turn on
Please check the charger connector for dirt, if possible take an old toothbrush and clean with alchohol, let it dry and refix everything. should work.
Jul 23, 2007 | Sony Ericsson K610i Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
23 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
