Screen has a band on top part
I have an old console TV. It says LXI behind the door. The screen has a band on top part of it. It is not black, you can see through it. It sometimes makes words or pictures look upside down
    Scholar:
  • 86 Answers
The way that you are describing your problem it seem to be vertical foldover. this problem is in your vertical output and feedback circuits.check the vertical output transistor,ic, and yoke coupling capacitor. also check capacitors that could be out in your vertical bias and feed back circuits. an esr will do this in no time. the easiest way that i have found to check capacitors without removing them or even turning the board over is to get some alligator clamps and clamp one end to your esr and the other end to a wire and measure the cap. this way you will be able to read the cap and measure at the same time. also check resistors and transistors using the same method for hard to reach components. please rate my solution if it helped. thank you
Posted on Nov 13, 2009
How to change from analog to digital
If you have an old analogue TV and wish to keep it, buy a digital set top box (which is just a digital tuner with no screen), then connect the antenna and TV to that. These STBs are quite cheap, and a good name brand will give you an excellent picture, with one qualification.
This is that the old analogue TVs have a screen proportion of 4:3, whereas the digital broadcasts are 16:9. So by keeping an old screen you will lose a bit of the picture at each side, or see a black band at top and bottom.
If you don't like that, you will need to buy a flat-screen (digital) TV and toss out the old one. There is a huge range of sizes and prices, so if you look for a special from a recognised retailer who will stand by the warranty, you would be OK.
May 31, 2014 | Orion LCD TV SLED2480 Sansui - 24"...
Disney princess tv suddenly narrowed the visible part of the screen. Now everything is squished into a two in wide band with all the rest of the screen is black.
if that 2 band according to you from top to bottom,it has a defective vertical stage.if this two band appears one on top and one at the bottom,it`s on vertical stage.leaky capacitors,resistance changed or resistor devalued ang ic`s, are too weak to amplify a signal to make the screen complete....
Jan 29, 2014 | Disney 13" TV
Black box on screen
Without a picture of it it's hard to say what you mean. Sometimes on a CRT TV the vertical scan doesn't fill the screen, but that would cause a black band both top and bottom. The usual cause is a capacitor drying out. But only a qualified tech should look into that.
Jan 04, 2014 | Philips Magnavox TS3260C 32" TV
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
Large colour lines / bands on screen
Thats your midddle driver board on the botton m8.
Try the technique on this video if that doesn't work ,replace the board by with another of the same part number.Cheap to buy.Ebay.LCDTV Spares shops online
http://www.youtube.com/watch?v=9NPobj0_GSo
Jun 05, 2010 | Panasonic TH-42PX60U Television
Green band
http://www.mitsubishi-tv.com/support.html
click warranties...
Important Warranty Announcement for LCD TV Owners
Jul 26, 2009 | Mitsubishi LT-52244 TV
I can't get a full screen picture black band across top and botto
try adjusting the aspect ratio. on widescreen movies or shows you will still get the black bands on the top and bottom. if you play with the aspect ratio you can sometimes get rid of it
Apr 19, 2009 | Protron PLTV3250 32 in. LCD Television
I have a Slim-View LXI TV Model # PTV 515 AHO1 Has no Picture
while i dont have a true answer, I can tell you its a magnavox tv sold by sears produced back in 93. Ours just started doing this last week. I couldnt find any help online so we replaced it with a new led flat panel. WOW what a difference, the LXI was great for the past 17 years but the new tvs are better. We put the LXI in the garage because we couldnt throw it away. That tv was like a family member, if i figure out how to fix it i will post the how to.
Feb 24, 2009 | JVC Televison & Video
PS2 Locks-up during running
Maybe the TV is old or the disc is scratched
Aug 18, 2007 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
