Question about ASUS Pundit P1-AH2 Barebone
Problems installing a new processor
I have installed a new processor amd x2 4800+ but the mainboard will not boot
  • 46 Answers
Take proc. out and check if you bent any pins when replacing it. make sure you installed it correctly. some motherboards wont boot if cooling fan is not connected to motherboard. make sure motherboard supports new proc.
Posted on Jan 23, 2008
I just bought your AMD Athlon ll #x2 255 to replace replace my old one. I see in the instructions that I have a socket 754 and the new one is different. I/m trying to upgrade my computer. i also got y
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Roger Gross.
Yes your new AMD Athlon 2 X2 255 processor is made to fit both AM2+ or AM3 sockets.
Since your current socket is 754, you will need a new mainboard and DDR3 RAM to go with your new processor.
ASUS make very good mainboards. The ASUS M4A88TD-M EVO/USB3 mainboard is a good companion for your new processor. Install DDR3 1333MHz CL9 RAM from either Kingston or Corsair. 2X2GB modules should do nicely.
Feel free to contact me should you require additional assistance.
Take care!
Dec 22, 2011 | AMD Athlon II X2 255 ADX255OCGQBOX
Will windows xp supported in amd sempron 145?
No it should not.
However your post does have one confusing detail - XP when installed does not reside on the motherboard but on a Hard Disk Drive. Parts of it will be loaded into memory when you boot up the PC.
If you mean that you are also installing a new Gigabyte MB under an existing installation of XP, you will probably still need the XP system disk for a reinstall of XP as it may not recognise the new MB.
If you are newly installing XP in an existing PC with the specs you mention, it should be ideal. It is best to have enough memory on board, at least 1 Gb.
Nov 20, 2011 | AMD Sempron 145, 2.8 GHz
It takes a full 7 minutes for the computer to boot up. there's 2 gigs of DDR2 800 Ram and a AMD Athlon x3 435 processor on a biostar ta785GE 128m motherboard. Its been like this since I got it out of the...
Take a look at my published guides entitled:
How to Perform a Defragmentation of your Hard drive, to increase Performance!!!
How to Decrease the Boot Time of My Computer/Laptop!!! Make My Computer Quicker!!!
The more processes that your computer has to execute on start-up the longer it is going to take to fully boot up.
Unistall any applications that you do not need.
Keep that mainboard cool, install fans in your chassis.
Take care!
damnor01
Apr 13, 2011 | Biostar TA785GE 128M AM2+/AM3 AMD 785G...
Dont know from where to download drivers for amd-athlon LE 1640 to run newly installed window 7 propely
"amd-athlon LE 1640" is only your CPU ie the processor for the Mainboard of the PC. The CPU do not need any drivers. To get the needed drivers you have to make know the Mainboard info ie Type/Brand/Name.
Oct 27, 2010 | Computers & Internet
I need to run Autocad 2010 on my computer but it won't even instal because I have an AMD 3000+ 2Ghz processor. Is it possible to upgrade the processor without buying a whole new computer?
Autocad 2010 needs SSE2 to run.
The only Semprons which didn't have SSE2 are those for socket A, so I assume you're running a socket A mainboard. I checked and there are no socket A processors that support SSE2 unfortunately.
I think that you could replace your mainboard and the cpu cheaply witha a socket 754 mainboard (which supports SSE2 CPUs and should run with your old ram).
However I advise to upgrade to newer system with AM2 socket or so - they aren't expensive and the increase in performance in power-hungry applications such as AutoCad will be noticeable.
Oct 12, 2009 | AMD (SDA3000BOBOX) Sempron 3000+, 2 GHz...
PCI cards don't function
as been have ssen in picture and specs of your mainboard you have a integratd vga vard and a agp slot. so solution may be this
with old integrated vga open bios program go to disply and choose pci input first. this enable you to boot from pci slot with a new vga save setting switch of computer put on new pci vga and try.
if no option to activate pci init first , sorry you can not boot any vga from pci , but only from agp slot.
Apr 05, 2009 | AMD Athlon , 750 MHz Processor
Sp3 will not install on sr1620nx
There are some problems installing SP3 on AMD Processor PC's
If this is an AMD Based system see http://msinfluentials.com/blogs/jesper/archive/2008/05/08/does-your-amd-based-computer-boot-after-installing-xp-sp3.aspx
Or do not install just apply other updates
Jan 25, 2009 | Computers & Internet
I Can't Install Windows XP Operating System on my AMD Sempron Computer
cheak ram clean disk ? try one ram do partion on hard drive del it then make new one then slow formatt then install ok and update call it in
Jan 18, 2008 | AMD Sempron 2400+, 1.667 GHz (sda2400box)...
ASUS Pundit P1-AH2 Barebone Logo
171 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
