Question about Amptron amv MW9BBK Monitor
My amptron mw9bbk monitor has ghost (shadows) near each text character. Is there a fix for this issue?
    Sergeant:
    Champion:
  • 219 Answers
Check the monitor is set to the correct resolution. (1400 x 900)
Posted on Nov 13, 2009
Monitor light flashes but no picture
Main computer is not on or on board screen card faulty
Dec 30, 2013 | Amptron amv MW9BBK Monitor
HP w19b "shadow"
OSD has no shadow shows monitor itself is OK and problem is in cable. Barrow a cable from friend and confirm the result.
Regards,
Sep 02, 2008 | HP Computers & Internet
The amptron monitor will flick on for a split-second (long enough for me to momentarily see the desktop) with the center power (green light) lit...for a split-second. then its off for a few (3-5) seconds....
90% of the failed LCD monitors are due to bad capacitors (bulging top/seal, or leaking) in the power supply, or bad solder joints, etc.. You can look for them first. Please see the pictures here to see what to look for: http://s807.photobucket.com/home/budm/allalbums
Please post back so we can guide you further and it will help other people also.
Apr 06, 2010 | Amptron amv MW9BBK Monitor
Shadows around the objects
One common cause of ghosting is an inferior monitor cable. Remove any extension cables and check again. The monitor may be getting interference from another device nearby, such as a printer, for example. Try turning off/ disconnecting other devices and see if the ghosting disappears. If so, you could buy a better shielded cable, or rearrange your components to prevent the interference.
That would be a simple fix if it works....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 24, 2009 | Acer AL2216W LCD Monitor
Amptron monitor driver
I don't think this monitor needs a driver for WinXp.
Check out: http://tekgems.com/Products/et-26521-mon-amv19wa.htm
All I see is a cd with a user guide.
Mar 17, 2009 | Amptron amv MW9BBK Monitor
Shadowing of text
YOU ARE EXPERIENCING THE EFFECT OF GHOSTING.
iT CAN BE FIXED
cREATE A 1200X1600 100% WHITE .GIF TO USE AS A SCREEN SAVER. (IN WINDOWS YOU CAN ADD IT TO MY PICTURES SLIDESHOW)
Set this slide show to run after 2 minutes of non use.
Set the nonitor to power off in a short amount of non use.
say 15 minutes.
Do that for a couple of days and the ghosting affect will go away . You can then turn to a more reasonable screen saver.
I received this information from www.beginnercode.com
Feb 16, 2009 | HP L1706 17" LCD Monitor
Problem with monitor
Shadow after text is usually caused by an impedence or termination issue. If you have a multimeter, check the VGA connector pins 1 2 3 (R G B) vs GND should be 75 ohms. If not, cable is damaged or poor quality. Try a new VGA cable, should cost $5+
If the edge of the text is wavy, there is too much jitter in the signals coming from the graphics chips. No fix possible.
If the edges of the characters are lumpy, then the panel has a cheap A/D converter, try using it in DVI mode instead (white-white connectors instead of blue).
Nov 15, 2007 | Computers & Internet
Shadowy/Ghosting Display on my monitor
Check the VGA connector and the cable. It might be loose.
May 24, 2007 | BenQ FP71E 17" LCD Monitor
Ghosting image after 3 years of perfect operation
ghosting is a memory problem, the monitor has a memory chip this helps with the video rendering to display the image, the chip can over time become damaged like any other memory chip, its its read use delete type but some times it can take longer to delete this then gives you the ghost shadow. it can sometimes be the software glitching, but there is no way to fix the firm wear on the monitor as the chip is pre programed before the monitor is assembled.
Aug 11, 2017 | Hyundai ImageQuest Q995 19" CRT Monitor
Amptron amv MW9BBK Monitor Logo
138 people viewed this question
Top Amptron Computers & Internet Experts
David Payne
David Payne
Are you an Amptron Computer and Internet Expert? Answer questions, earn points and help others
