DVD-M108 SAMSUNG DVD PLAYER DOES NOT LOAD
The above captioned DVD player DVD-M108 was purchased in 2002 in singapore. Of late whenever I load a vcd or Audio CD it says loading and I can see the CD running for a very long time. It is in loading position for a very long time and then it says " NO DISK ". Sometimes when I use a DVD it loads for a very long time say almost 7 yo 8 minutes and then the picture is seen. It never loads a vcd or audio cd. Kindly let me know wheather it is a problem with the pick-up lense or PCB. Thomas K. Abraham Samsung DVD player DVD-M108 displays loading but does not read any DVD/CD or takes too long
  • tom22 Mar 26, 2008
  • 99 Answers
SOURCE: DVD/CD will not load and ejects
junk it and buy a better player...cheap dvd players fail quickly..
Posted on Mar 31, 2008
  • 170 Answers
SOURCE: Insignia NS-7PDVD portable DVD player - no picture
The unit is failing and is not worth repairing. There is either a short in the wiring that leads to the screen, the inverter board os failing, or the decoder is failing. These are all hardware problems.
There are several tests to find where the problem may be, but the average consumer doesn't have the ability or access to parts to fix these issues.
Posted on Apr 17, 2008
  • 6 Answers
SOURCE: Player unable to load discs when inserted
http://forum.videohelp.com/topic350059.html
I think I found these adjustments! There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Posted on Nov 27, 2008
SOURCE: I just doesn't load/read CD's.
I had the same problems with my four year Denon DVD-3910 and the only solution to it was to replace the laser unit with a new one.
There are some repair service on EBay that offer new laser units for only about 50 € and are also willing to change the laser unit for an extra charge of just 30 €.
After this replacement your Denon DVD-3910 will work fine again.
Posted on Jul 26, 2009
SOURCE: jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
Posted on Jan 25, 2010
Canot be load to my cd/vcd player.But no problem with any computer
Most players only support fat 16 or 32, ntfs is likely the issue.
Feb 27, 2014 | Samsung ( MP0603H) 60 GB Hard Drive
My Samsung Blu-Ray player P1590 doesnt play regular DVD's. is this normal? Whenever I put a regular DVD it tries to load but it eventually posts a message on my TV screen saying "unable" to...
I have a Samsung BD-P1490. When I turn is on the display reads "Load." It never displays "No Disc", or trys to play a disc if one is present. I have never updated the firm ware. Any ideas?
Jan 20, 2011 | Samsung BD-P1590 Blu-Ray Player
How do i turn off the closed captioning
hello mjeanfox, caption is either present on the TV menu settings or the VCD/DVD player menu settings , check for the menu settings of both your in use TV and DVD player. It would help if you can browse your manuals.
Feb 04, 2010 | Televison & Video
Unlock my DVD player to watch VCD's.
VCD's do not have "regions" specification. The DVD player either can play VCD's, or cannot play VCD's. It's a format that is not very popular among manufacturers. I have two players that both play my VCD's, but I had to make sure they accepted that format before I bought them. This player accepts DVD and CD's but it did not say VCD's. It's kind of a proprietary format that was only really popular overseas. The PHILIPS DVP5140 is one that I just found that does play pretty much everything.
Oct 28, 2009 | Televison & Video
Dvd player wont load disc
try cleaning the lens first.then load a disk.try a different disc like VCD, CD etc.if only the DVD's are not read, the lens and the mainboard itself is faulty.but, if after cleaning it, it goes ok ,then its just dirty.
May 28, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
May 11, 2009 | JVC XV-N322 DVD Player
Unable to play VCD on Sony DVP-FX810
You have to contact Sony Support for Singapore to get support for it.
Here is a link to their website
Jul 20, 2008 | Sony DVP-FX810 Portable DVD Player
Shinco SDP-1731A 7" dvd player
How about cleaning using compressed air( it looks like an aerosol paint can)? Cleaning using cotton buds will only clean the outer side of lens, compressed air in can will clean the inner side of the lens. its like cleaning you computer keyboard, ( actually compressed air in can are used to clean the keyboards). A 30psi pressure of clean air is enough to wipe the dirt out of dvd lenses.
Aug 23, 2007 | Shinco Initial Technology Portable DVD...
Samsung DVD-M101
Reset the player back to its factor settins sould resolve the problem. Press and hold down the stop and the play buttons at the same time for 15 seconds,then restart player . This player should be just as you first bought it.
Jun 21, 2007 | Samsung DVD-M101 DVD Player
Televison & Video Logo
422 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
