Question about Adobe Acrobat 7.0 Professional
I'm having problems with the highlighting tool in Adobe Acrobat Standard 7.0. Instead of highlighting it is deleting the text and just showing the higlights. Please explain how to fix. I've tried restarting computer and it still does it. There seems to be no way of getting info back after it does this. Please help!!
  • 691 Answers
Run a repair on Adobe Acrobat
Posted on Nov 19, 2009
I have a scanned PDF document that I want to highlight and previously when the text wasn't recongnized it would ask to convert. At one point I checked the "do not ask again" box and now I am...
Basically Acrobat comes with a feature called as OCR (Optical Character Recognition) which helps acrobat in recognizing the text being used in a particular scanned document.
Just for the information, Acrobat 7 used to come with OCR accuracy of approximately 85% which has increased to 95% accuracy in the latest version of Acrobat (Acrobat X)
Now, in Acrobat 7, what you need to do is try running the OCR again on this document by following the steps mentioned below:
  • Open the document in Acrobat 7
  • Go to Document menu at the top
  • Click OCR text Recognition option under that menu
  • Then Recognize Text using OCR under that
  • This will open recognize text dialog box
  • Make sure All Pages option is selected in the new dialog box
  • Then click the edit button available in the same dialog box
  • This should open recognize text setting dialog box
  • Select Clearscan option in PDF Output Style drop down
  • Click Ok and then Ok again which should start the OCR on the open document
  • After OCR successfully completes try highlighting the text and see if you can do it
If you are still unable to do it, I would suggest you to download the trial version of Acrobat X from adobe.com which is a fully functional version which you can use for 30 days. After downloading this trial try opening the same document there and try running the OCR again and perform the highlighting of text again in Acrobat X itself.
If it still does not work please reply back with the results of the above mentioned steps and we can try performing some other workarounds to make the text recognizable.
Jun 01, 2011 | Computers & Internet
Tip
Error "the application is being terminated because of memory corruption"
When you exit Acrobat 7, Acrobat returns the error message,"the application is being terminated because of memory corruption."
Solutions
Do one of the following solutions:
Solution 1: Install the Acrobat 7.0.8 update.
If you have Acrobat 7.0, choose Help > Check For Updates Now to install the update. Alternately, you can download the update from the Adobe website at www.adobe.com/downloads/ .
Solution 2: Remove the files from theAcrobat Organizer folder.
When you remove files from the Acrobat Organizer folder, you force Acrobat to rebuild the Organizer database. This process replaces any damaged files in the Organizer that may be causing the error message.
To remove the files from the Acrobat Organizer folder:
1.Choose Start > Run.
2.In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Organizer70.
3.Delete or move all filesfrom this directory.
Solution3: Remove the files from the Updaterfolder.
You may receive this error message after a failed update, indicating that the files in the Updater folder are corrupted.
To remove the files from the Updater folder:
1. Choose Start > Run.
2. In the Open text box, type:%UserProfile%\Application Data\Adobe\Acrobat\7.0\Updater.
3. Delete or move all the files fromthis directory.
on Mar 20, 2010 | Adobe Acrobat 7.0 Professional
What is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
HIGHLIGHTING THE TEXT
Is it possible to re-scan or re-save the document you are working on at a higher resolution?
While 144 dpi is listed as the lowest possible resolution to scan OCR text, sometimes it is finicky at that level. Also, you might want to optimize for OCR, straightening and taking out the speckles and such.
Hope that helps and isn't too elementary to your issue.
May 03, 2010 | Adobe Computers & Internet
Adobe 7.0 : The highlighting tool is erasing my text and just
if you do not save it ...just go to edit ..in the left upper corner ...and roll back a few times..it will fix..also reloading the original document will do that too
Nov 13, 2009 | Adobe Acrobat 7.0 Professional
Highlighting a graphic or scanned text in pdf file
If the text is editable you can use the TouchUp Text Tool.
For images use the TouchUp images tool.
Both are located in the Tools Pallet under Advanced Editing.
Oct 21, 2009 | Adobe Acrobat 7.0 Professional
Suddenly all my pdf docs are opening in Adobe reader instead of Acrobat Pro. Even the Acrobat.exe file in my C:Program Files\Adobe\Adobe Acrobat 7.0\Acrobat folders opens Adobe reader instead of Acrobat...
Go to My Computer. Tools > Folder Options > File Types > Then Browse PDF Registered File Type . If you can see " Details for PDF extension " and you can see a change button, you can click that button and browse for your Acrobat Pro main program .
Aug 18, 2009 | Adobe Acrobat 7.0 Professional
Deleting words in Adobe 7.0 Professional
You can do that to some extent (if you do extensive editing, it can mess wit the layut of your document).
Go to Tools/Advanced Editing/TouchUp Text Tools. Select the text to delete and presse delete or type the new text.
If you are not able to select text, maybe your document was scanned as an image only. In that case, go to Documents/OCR Text Recognition and do a text recognition of the page or pages you want to edit or of your entire document. Then go through the steps stated above and tr again.
Hope this helps.
May 05, 2009 | Adobe Acrobat 7.0 Professional
Mouse won't right or double click after Adobe Acrobat Standard 9
it may have just changed your pointing devices
in control panel find pointing or mouse devices open it and in there
you should find where you can check the settings for mouse or change them.
If all settings are intact I would uninstall the adobe and install a previous version
let me know if this helps
Jan 10, 2009 | Dell Latitude C610 Notebook
Adobe acrobat v7 can't open file
Do this:
1. Exit Acrobat.
2. Choose Start > Run, and type: %APPDATA%\Adobe\Acrobat\ into the Open text box. Click OK.
3. Right-click either the 6.0 or 7.0 folder, and choose Delete.
4. Start Acrobat and attempt to print.
Note:Acrobat preference files contain application settings such as toolbar arrangements. When you restart Acrobat, new preferences are created automatically based on application defaults. Deleting preference files will not result in the loss of saved documents.
Or, if u have having Quarkexpress in your machine update the version. Quarkexpress also creates PDF files, maybe this is where it was created from
Mar 14, 2008 | Adobe Acrobat 7.0 for PC
Adobe Acrobat 7.0 Professional Logo
104 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
