Question about Electronics - Others
I got tons of my assignment on my memory stick and it is stop and undetachable with any PC. Please help how to retreive all data on my pen drive,
  • 3,600 Answers
Just plug it into another computer if it is a usb pin drive, and you can detach it.
Posted on Nov 13, 2009
Why my pendrive not open in my pc ?
Are any of your devices (TV, PC) Apple ? I\'ll assume not, and describe the procedure for Windows (XP)
First, has the pen drive any files on it (for example film clips which can watch on your TV ? Are these valuable (you do not wish to lose) ? If the answer is \'no\', then you can try these two steps (for windows XP):
Your pen drive works in your TV, but not in your computer. This suggests that maybe it is conflict of formats used by your TV and your computer. Consult your TV user guide to find which formats it is able to use. If your computer is a windows computer, it will most likely need disks (pen drives) formatted as FAT32 or NTFS. If eiher of these are mentioned in TV \'s user guide, that is good.
1. Left click on the windows start button at the bottom left of screen (a kind of flag symbol). Right click on \'My Computer\' or \'Computer\'. A drop-down menu will appear, from which you should select \'Manage\' by left clicking. A new window will open: some in this window will be an icon with the words DiskManagement by it. Double click or single, can\'t remember and yet another window will open, with information about all your disks, including your memory stick. Somewhere on this screen against that disk (which might be reported as \'Disk 1\' in the lower box) it should give the format. This should be either FAT32 or NTFS. It may be RAW or not recognized. If it says exFAT I fear there is no easy way to proceed, and you stop. (this might be a problem if your PC is running Windows XP, but not if it uses Windows 7 or 8). In any case you can right click in lower right box against the pen drive entry (NOT YOUR SYSTEM DISK !!) which bring up a drop down menu which should contain an option for formatting. Formatting will ERASE ALL DATA ON THE DRIVE BEING FORMATTED so choose the correct one. If given the option you should choose FAT32 and Full format (not quick format). Leave all the settings as default values, and proceed. This mat not work, in which case ....shut the DiskManagement Window etc. and
2. Click on the Start button again, and select All Programs, and from that Accessories, and from that command prompt (the symbol being a small black square). A new window with a black background will open with an ">" prompt . You will have remembered the letter assigned to the pen drive, from either the Windows file explorer of DiskManagement. Type "FORMAT XXX: /fs:FAT32" and press return: the disk will be formatted. XXX is the letter assigned to the pen drive, which might be G or H for example. Ensure you get the correct one, if you are unsure do not proceed. Formatting a disk will result in all data on that disk (including a pen drive, and a harddisk) being lost. If successful this may take some time. Even if unsuccessful, it may take some time. In the latter case, I may have further suggestions to help. Please report back.
11.June.2014
Jun 08, 2014 | Transcend (589307) Media
I have transcend JF V30/4GB pen drive. Recently i am getting in the pen drive that i cannot do any format in the pen drive nor i cannot copy/delete the files in the pen drive. it was showing that...
Hello and Welcome to FixYa!
Kindly try this solution:
  • Connect the USB stick to another computer and copy all the data.
  • Download this file (click here) to that PC and format the USB stick using this program.
  • Now try to connect the USB stick to your ACER laptop and see if it works.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I am having one 4gb pendrive its not opening. now im inserting my pc please recover it.
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/index.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the pen drive (use quick format), and then use above mentioned software to scan again the pen drive and recover your files.
Apr 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How would you save a story on micro word with a memory stick
Hi Friend,
Please follow the gevin instructions-
1-Insurt the memory stick in USB port of the CPU (USB port available in front and backside of the system)
Note-mainly system detect memort stick automaticaly,some time not detect at that condition go to tme my computer maange option(after right click of the my computer you will be able to see the manage option and go to the device maange and update the USB driver)
2- Copy the data (micro word)
3-Past the data into pen drive (memory stick)
4-disconnect the memory stick
Thanks,
Mar 10, 2010 | Computers & Internet
I having HP Pendrive. It is having data inside. But, while trying to open my pen drive.It is giving the error( Please insert pen drive) But in properties is showing 0 GB. Even i can't to do the format...
The stick is dead as a dodo, the data is gone. Next time remember that a USB memory stick ages every time you put some data on it so it wears out very quickly. so it should never be used to carry data that hasn't been backed-up on another media.
Mar 09, 2010 | Electronics - Others
How can I download mozilla foxfire to a memory stick
There's no need to uninstall the Mozilla Firefox that is currently installed in your computer.
All you have to do is to download the executable file (.exe or installer) and direct it to your memory stick. Here's how:
1. Connect the memory stick to your PC.
2. The PC will assign a drive letter.
3. Download the Mozilla and browse for location.
4. Direct the file that is about to download to the drive letter assigned to the memory stick.
Once the Mozilla Firefox is saved in your memory stick, you can now connect the memory stick to your laptop and install the Mozilla.
Good luck and have a great day!
Feb 20, 2010 | Mozilla Firefox
Cant Format pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Oct 01, 2009 | Transcend (589307) Media
My transcend pen drive didn't blinks...?
the connector that is build into the pen may be broken, if i were you i'd send pendrive to onrack recovery company, as home-way-fixing may corrupt data on pendrive
Sep 22, 2009 | Transcend (589307) Media
Problem with 32 GB kingston pendrive
i hv a 32 GB kingston pendrive, it can copy any type of data but whenever i copy from pen drive into my pc or copy from my pc to pen drive, it shows multiple empty folders in the same folder n audio-video files got currupted, softwares too. and also unable to delet
May 11, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to remove write protection from my pen drive
Dear,
Just do one thing
Copy the data of Pen drive to PC and format the drive. Now paste the data back to the pen drive.
It may work fine onward.
Please try it.
Regards,
Rakesh Kumar
Apr 07, 2009 | Kingston 4GB Secure Digital High Capacity...
Electronics - Others Logo
16 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
