Question about Amana Dryers
LGA30AW Dyer Runs for awhile, then wioll turn itself off. When I try to restart it makes a buzzing noise. If I let it sit it will turn on once more but only a short time.
  • 26 Answers
The problem here is that the motor is starting to go bad. The start winding wires are going bad. When the motor gets HOT, the thrmal fuse turns the machine OFF until the motor cools down and then it HUMMS as it tries to start or will just HUMM and not start at all.
When you replace the motor, ALSO check that the hole in the wall to wherever it goes out is NOT CLOGGED UP by a birds nest or LINT BUILD UP that will restirct the hot air from exiting the dryer.
PLEASE CHECK this so that it will not damage the new motor you put in.
Posted on Nov 20, 2009
2004 Saturn Ion standard. Is making a loud humming/buzzing noise. Sounds like it is coming from the front right part of the engine (where the belts are and alternator). It makes the noise when idle and...
More info - If it only makes the noise when the car is moving its probably a wheel bearing - if it makes a whining noise whether its moving or not it sound like the power steering pump is on its way out - it could be as simple as adding fluid - start the vehicle and while sitting there turn the wheel left and right - the noise should get louder and softer - if it doesnt - its one of the other accessories - a/c pump or the alternator itself -
Jun 06, 2014 | Cars & Trucks
I have the samsung DLP HL-6163W model. I've had this TV for 6 year, and have logged many hours on it. Tonight, the TV started making a buzzing noise in the back, and the colors got all screwed up. I...
This tv have a colors wheel design in it to this tv.The buzzing noises and the colors are all screwed up because the colors wheel is worn out and spinning off of is axis and rubbing it against the wall of it hall of the steal box frame that hold the colors wheel itself.Don't attemp change the colors wheel by ur self,if u have no mechanical skills.Bacause the colors wheel itself sit way back of the tv,have to take out many mechanicals parts,before can come to the colors wheel itself to replace it.Because u will regret it later if u putting the colors wheel itself in wrong.Hire a tv repair person to replace it.
Apr 04, 2011 | Samsung HLP6163W 61" Rear Projection...
Won't agitate nor spin
Sounds like a faulty transmission. Also, make sure this machine is not sitting in a cold environment. If it is...run a blow dryer under it for awhile and try again. But really I think the transmission is gone.
Aaron
Jan 24, 2010 | Whirlpool Washing Machines
My Maytag dryer buzzes when I push the start button. If you hold it in, the dryer will start but makes a noise, almost like a bad belt. After a few minutes the dryer will shut itself off and will not...
Remove the belt from the motor and push 'start'. If the motor makes loud noises, squeals, or the shaft has side play in several directions, then it probably is the motor. Replace it. If the the motor runs quietly, then check the drum by hand to see if it is making excessive noise while turning. There should be a little resistance to turning, but not real difficulty. Hope this helps.
Aug 13, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
A loud intermitant buzzing coming from the back of the fridge
either the noise is coming form he ice maker fill valve( but if its of and still aking noise i doubt it. it also possible that the noise is coming from the compressor itself, overheating nad trying to restart in which case would give a slight "buzz" noise for 5secs or so then "click" off, and wait maybe 3 min to restart again. look for melted ice andperhaps your ice dream ont as hard as it should be???
Feb 19, 2009 | Amana DRB1901C Bottom Freezer Refrigerator
Kenmore Clean Touch dryer making buzzing sound and
Ya, happened to me. Sounds like you may have a clogged vent. (in the tube, or the dryer itself. Try cleaning that out really good. Then, double check that the venting is secured properly. If not, may overheat and shut down. I think that's what's going on. After you clean tubing (And the inside tube on dryer), the buzzing will continue for a while (days) until itr resets. If it runs after this, but still buzzes, that's your problem. Hope this helps you!
May 09, 2017 | Whirlpool LGQ9858P Gas Dryer
Amana gas dryer Mod# LGA30AW
yea sounds as if the motor itself is overheating, replace the motor would be the solution
Nov 10, 2008 | Dryers
Frigidaire side by side fridge
Power to compressor must be off (about 5 minutes) before a restart should be tried. Some of these relays are thermal and must cool down before power is reapplied.
Sep 04, 2008 | Frigidaire FRS26R4A Side by Side...
Dryers Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
