Question about Whirlpool Dryers
Whirlpool electric dryer. You push start button, dryer tries to start, tries to turn over, whines and shuts down, locks out and can try again in a few minutes may or may not start that time
  • Whirlpool Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check or replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Posted on Nov 14, 2009
How do I fix my Whirlpool dryer that tries but won't spin the clothes or turn on?
The overheat sensor may be defective. In addition, the belt may have stretched resulting in uneven rotation of the drum. If you use softener sheets, there may be residue clogging the discharge of the drum.
Jan 19, 2015 | Whirlpool Dryers
When the start button is pushed the dryer buzzez, but it does not turn on
sounds like the motor,open the door,move the drum,if you can't move it you could have something in the blower wheel and jamming the motor or the belt could have broke and jamming the motor or just a bad motor,if it moves try this to see if it starts,open the door,hold in the door switch and spin the drum and have someone push in the start button,if it starts there's a flat spot on the motor,this could happen right away again or it might not happen again until it stops on the same spot but it's the motor
Jun 05, 2011 | Whirlpool LER4634J Electric Dryer
Dryer lights works, but when the start button is pushed the drum does not spin. the timer shows the minutes counting off, but no spinning. the dryer worked yesterday, but no today. dryer is a duet...
I am having the same problem. Dried towels last night. This morning, I loaded it, turned it on, it did not lock the door or start drying (spinning) but the timer started counting down. I pressed Cancel twice, unplugged it for a few minutes then tried again. Problem still exists. Any suggestions?
Aug 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Electric dryer keeps stopping
Most likely, the operating thermostat has failed, and the high limit thermostat turns off the dryer when it gets too hot. When it cools down, it will start again.
Apr 06, 2010 | Whirlpool GEW9250 Electric Dryer
My whirlpool dryer just beeps when you try to start it. The panel is lit up the door is shut, push start and it just beeps...any idea what the problem is
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control Locked light is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If holding doesn't unlock the feature, it is likely a faulty interface. I am having the same problem with my Whirlpool dryer and it is the interface, but it seems that a lot of people are able to correct the issue just by pressing the End of Cycle button for 3 minutes.
Here is a link to parts, numbers, and prices from Sears:
http://www.searspartsdirec t.com/partsdirect/getSubComp.pd?modelNumber=GGW9250PW1&productCategoryId=0151200&brandId=1198&modelName=RESIDENTIAL-DRYER&diagramPageId=00001&componentDescription=TOP%20AND%20CONSOLE%20PARTS&documentId=W0508037&blt=06
Jan 09, 2010 | Whirlpool GEW9250 Electric Dryer
I press the start button, but the dryer will not start.
ok open the dryer door look for a button inside where door shuts against hold that button down with other hand spin the dryer have some one push start button let it run for a sec then shut door and it should start
Dec 23, 2009 | Whirlpool LER4634J Electric Dryer
I HAVE A DRYER THAT WAS WORKING FINE, THEN TURNED OFF. I PUSHED THE BUTTON AND IT WOULDN'T TURN BACK ON. NEXT MORNING TRIED AGAIN AND IT TURNED ON FOR 5 MINUTES THEN SHUT OFF. WON'T TURN BACK ON. I THINK...
Would first check the door switch. This can be done by finding door switch, with door open hold in switch and jiggle around while pushing the start switch. If it tries to start, replace the switch.
Mar 24, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
96 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
