Question about Peg Perego John Deere Gator HPX Ride on Toy
Replaced reverse switch in peg perego because gator stopped going in reverse. now gator goes forward in reverse. 1st and 2nd gear are fine.
    Genius:
  • Peg Perego Master
  • 1,508 Answers
The polarity is backwards, switch the wires around on the motors
Posted on Jun 14, 2012
  • 60 Answers
SOURCE: Peg Perego Gator goes in reverse
Your switch/harness may need to be unplugged and turned around. Take off the shifter and you can see it there.
Posted on Mar 11, 2009
  • 19 Answers
SOURCE: !st gear won't work
I would replace the shifter assembly. It seems to be a better upgrade with the switches built into the shifter itself. It also has the wiring with it.
As long as the battery seems to work and the motors are going in one of the speeds, then there is not much to the vehicle.
It is a specific Peg Perego Switch assembly.
Hope this helps
Posted on Apr 21, 2009
  • 156 Answers
SOURCE: peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
Posted on Jun 09, 2009
  • 156 Answers
SOURCE: I have the Peg Perego Gator and when running it
It might be the peg perego motor in the rear that is going bad, thus causing the fuse to trip. I had the same problem with my kids toy so I contacted a service center for Peg Perego at 1.801.655.0800
They were able to help me over the phone and get the right parts out to me.
hope this helps
Posted on Nov 05, 2010
Peg pergo John Deere Gator goes for about 2 seconds then stops suddenly
it almost sounds like a thermal fuse, but these don't have a thermal fuse, so id say it might be a bad shifter switch
Dec 28, 2013 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator left wheel wont engage in 2nd gear, just replaced both motors and problem still exists. Any help?
disconnect the wires from one of the motors and check to see if it works in all gears, then do this with the other motor, then swap the wires from the left side to the right and vice versa, if both wheels spin in all the gears then you need a new shifter switch
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
No forward gears just reverse
I had the same problem with my grandsons gator and I replaced the shifter switch. I called the peg perego department at 1.801.655.0800 and they sent me a couple of switches.
Hope this helps
Jul 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
2nd gear won't work
probably a bad/disconnected shifter switch first of all check to make sure that the shifter switch is connected underneath
Oct 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Only goes in 2nd gear
I would replace the high/low and reverse switch on this peg perego model.
I had the same problem so I got the parts from this site
May 08, 2009 | Peg Perego John Deere Gator HPX
!st gear won't work
Hope this helps
Apr 18, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
Peg Perego John Deere Gator HPX Ride on Toy Logo
365 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
