Question about Ricoh Aficio CL3500N Laser Printer
I emptied the waste toner bottle. Do I have to actually REPLACE it to make the error message go away?
  • 748 Answers
Look for a small cavity with transparent walls, through which a sensor shines a light beam to see if it's empty (clear) or full (toner blocking the light). Use compressed air to blow toner residue from it (do it in the open to not inhale the toner particles).
Posted on Nov 13, 2009
Testimonial: "Thanks for that tip. I also vacuumed out the whole container outdoors and when I put it back in the red light went out."
Toner is a safety hazard.Never inhale it. ALso never vacuum it witha reguar household vacuum. Toner causes static which can cause a fire or else it is so fine it will go through the vacuum filter and be blown into the air and people can inhale it. Its effects on breathing it in can be likened to asbestos.
Posted on Dec 02, 2009
3 Suggested Answers
jaylex
  • 417 Answers
SOURCE: We removed the waste toner bottle and it won't reset the error message
You will need to vacuum all the toner out as in the machine there is a sensor that looks through the waste tank and checks that it is clear. You can also wash the tank out then install it and you will not have the problem.
Thanks J
Posted on Jan 28, 2008
SOURCE: can you resue a waste toner bottle
Change the waste toner bottle. :-)
Posted on May 14, 2009
Waste toner is almost full on Savin C9020
The bottom left portion of the display gave the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print, however this message would not go away.
To Fix:
Power down the printer using the normal shutdown method.
Open the top front door.
Remove the cover directly below the 4 toner cartridges.
The removable cover below the toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster. Continue until all the toner has been removed.
Push the clear plastic tab back in place. Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
The check waste toner bottle message keeps showing up,even though its empty
Check that the bottle is also clean from toner residue especially around the top where the lid is.
Use a clean rag or paper towel to wipe away all the toner.inside and out.
This should make the message go away
Apr 06, 2011 | Kyocera Mita FS-3800 Printer
Our imagistics 8130 has the replace waste toner bottle error message on but the waste bottle is empty and I turned a wheel above the waste toner bottle and nothing.
Hi how are you this is jack ... jack_pak@hotmail.com
Dear you wash the waste toner bottle clearly. But error still your copier you check the waste toner bottle dection SENCER OR IS DIRTY CLEAN IT..
PLEASE VOTE ME .
Thanks
Best Regards,
Aug 14, 2010 | Toshiba E-Studio 3511 Color Copier
Where is the waste toner bottle located on the Panasonic DP-4510 copier? If I empty it, will the message on the machine go away?
You can access the waste bottle behind the right side rear panel. Three screws. The wast bottle will slide out. the error will go away after emptying.
Jan 13, 2010 | Canon imageRUNNER 5020i Copier
Gestetner DCS424 error message: replace used toner bottle
There are 2 waste toner cartridges, be sure to empty these 2 cartridges . If you remove the waste toner in both cartridge it will automatically clear the error message.
Feb 27, 2009 | Gestetner Copier
DCS424 error message replace used toner bottle
Used Toner Bottle Full Ricoh Aficio 1035P
The used toner bottle is not actually a bottle at all. Not sure what you emptied, but it sounds like the actual toner bottle itself. The waste toner is contained with in the transfer belt unit. When you open the right side cover, this is the unit that is attached to the door. It is a brown belt that provides transfer of the image to the drum and separates the paper from the drum. Remove this unit by locating the release levers on either side of the transfer unit (push both of them towards the machine). After removing, you will need to actually take the belt unit off of the transfer unit. To do this, remove the two tension springs on either side, and then take a small flat bladed scredriver and release the clips that hold it down (you will see when you get started). Once you get it off, you will see the long blade that actually scrapes the toner off the belt. Dump the waste toner out this end. You will need to shake it pretty hard. A better (and cleaner) option is to vaccum it out using the crevace tool on you vac. Just make sure you completely empty it. Now....do everything in reverse.
Hope this helps,
Chad
Oct 07, 2008 | Ricoh Aficio 1035 Copier
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
If a new waste toner bottle is in place, then the printer needs a new motor, which can only be purchased through an Authorized Service Center.
Oct 24, 2007 | Samsung CLP-510 Laser Printer
Ricoh Aficio CL3500N Laser Printer Logo
534 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
