Question about Toshiba Satellite A135-S2386 Notebook
I upgraded my memory per Toshiba's website - installed the memory and the system will boot up, but then the screen goes blank - you can see the cursor, but nothing - I removed the memory and put back in the original and still have the same problem - Satelite a135-s2386
  • Toshiba Master
  • 4,924 Answers
When makes changes on memory ...always reinstall .and first go to bios and restore factory defaults ...optimal factory defaults ...
this will do to recognize the new modules ...and installing will aware the system about the changes..
Posted on Nov 13, 2009
I have upgraded my tc1100 to 1.5Gs of memory. The description on the memory module is ( Super * Talent D400SBG/H STT DDR-400 PC3200 SO-DIMM Hynix 1G/64X8). The problem is the computer initially boots into...
It sounds like that memory should be compatible with your tablet PC. It may be a bad memory stick -- try to replace it with a different memory stick (preferably from a different manufacturer) and see if it still gives you the same problem.
If you didn't have this problem before you installed the new memory, a different memory stick will likely correct the issue. You can also try removing the new memory and see if the PC boots up like it should.
Dec 08, 2010 | Compaq tc1100 Tablet PC
Can it support expanded ram - what is the upper limit on ram capacity
below are the specs for your laptop,
Standard Memory 64 MB (non-removable) Maximum Memory 192 MB Memory Expansion 1 socket Memory Comments PC100 SDRAM SODIMMs CPU Type 650MHz Intel Mobile Pentium III Model Comments 100MHZ FSB
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
buy more ram here: http://www.memorystock.com/orderitem.asp?it=330ms-069&MnfId=&MdlId=22646
May 20, 2010 | Toshiba Satellite 2775XDVD Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    What is the max ram for toshiba laptop model #
    Hi Fhiken!
    That modell comes with 256mb rab and supports up to 512mb ram.
    The ramtype on it is SDRAM
    I hope the info helped you
    Nic
    Aug 20, 2009 | Toshiba Computers & Internet
    Toshiba Satellite A215-S4757 blue screen of death and memory dump after changing out the processor (Upgraded from 1.82 ghz - 2.0 ghz). I turn it on it boots up and runs for about 1hr overheats and then...
    Hello my friend, Try to check  the fan of your CPU if that is properly connected and properly functioning. Usually if the it overheats then meaning the issue is the cooling part of the CPU. Also the memory try to check if it is supported with your new CPU installed.
    Hope this solution will help you solve the problem. If you ned more assistance just reply to this post.
    Thank you and Godbless.
    Jonas
    Jul 08, 2009 | Toshiba Satellite A215-S4747 Notebook
    Hard drive and memory
    the laptop should pick up a 20gb or 60gb ide hard drive with no problem
    Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
    BLANK SCREEN
    i think your system has crashed so you need to do recovery or do a fresh installation of your operating system. Your system is unable to boot due to corruption in system files.
    Jun 18, 2008 | Toshiba Satellite A135-S4527 Notebook
    Laptop Freezes
    it sounds like the memory may be at issue as it heats up it dies, then cools down.
    if you have 2 sticks of memory take one out and see if it will run.
    if not switch to other stick.
    if still not running remove all memory as the system should have 64 meg of onboard non removeable memory .
    as per this google :
    _________________________
    Memory Upgrade for Toshiba Satellite 2250XCDS, the Toshiba Satellite 2250XCDS takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory.
    windows may not boot and run at all with 64 meg so you can enter the bios screen and let it sit there,
    instead of trying to unplug the system to kill it just hold the power button for 10 seconds and it should die.maybe.
    Apr 30, 2008 | Toshiba Satellite 2250XCDS Notebook
    Screen is blank
    ram may not be compatble what speed u buy and what brand sodim ram did u buy hit reset button on botton for 20 sec take batery out and new ram to get old to work ok
    Jan 23, 2008 | Toshiba Satellite M45-S169 Notebook
    Toshiba Satellite A135-S2386 Notebook Logo
    88 people viewed this question
    Top Toshiba Computers & Internet Experts
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
